All this time that I've been seeing your picture, My feeeble!
![Surprised :o](./images/smilies/econ_oh.gif)
![Thumbs Up :thumbsup:](./images/smilies/econ_thumbsup.gif)
The 202 would use a standard #21 Coleman mantle. If I were you, when you get the lantern, I would obtain a standard brass 200A burner cap and swap out the ceramic burner cap. Those are like gold and sturdy as they may look, you don't want to break one. I'm glad you are going to use it. That helps make my day.
halfdome, Danny wrote:The guy who sold me this lantern suggested I do the following.The 202 would use a standard #21 Coleman mantle. If I were you, when you get the lantern, I would obtain a standard brass 200A burner cap and swap out the ceramic burner cap. Those are like gold and sturdy as they may look, you don't want to break one. I'm glad you are going to use it. That helps make my day.
Do I really need to swap out that ceramic burner cap? Im going to use it, not collect it.
If it was manufactured that way what's wrong with using it the way it came? Who knows it might break removing it.
Is this something off the shelf or do I have to order one from some collector?Danny
halfdome, Danny wrote:Thanks Jeremy, It makes sense to replace the whole tube since it just screws in & out. I'll watch the item to see if I can get it for very little. If not, I'll take you up on your kind offer.Danny
rainjer wrote:halfdome, Danny wrote:Thanks Jeremy, It makes sense to replace the whole tube since it just screws in & out. I'll watch the item to see if I can get it for very little. If not, I'll take you up on your kind offer.Danny
No problem. It is just sitting here collecting dust. I did not replace my ceramic burner but I do not plan on using it much. My understanding is that the ceramic burner may crack if you use it a lot. That is why they switched to the newer metal ones.
Jeremy
fastED wrote: at the same time I was bidding on a 1930's Coleman 243a, and I won it. It will be here by Friday.
