Weatherstrip question
Postby planovet » Wed Dec 17, 2008 4:19 pm
I'm using an EPDM (ethylene-propylene-diene monomer) seal for my weather striping around my doors. It did not come with an adhesive backing. What should I used to attach it to my door frame? Would a double sided tape work or will I have to use an adhesive (glue, epoxy, etc.) to keep it in place. I don't know what is best for sticking an EPDM material to a urethaned wood surface.
Thanks for any suggestions.
ImageMark (& Cindi)
planovet
The Cat Man
Postby Miriam C. » Wed Dec 17, 2008 4:30 pm
I got mine from Grant and it had double sided tape on it. You will want to get a better tape so it stays. I guess you could glue it but that is so much a bother. 8)
Postby tonyj » Wed Dec 17, 2008 4:31 pm
Are you sure there isn't a plastic tape over the adhesive? If not--3M automotive weatherstrip adhesive sold in any auto parts store should do the trick.
tony
tonyj
Images: 160
Postby toypusher » Wed Dec 17, 2008 4:41 pm
Mark,
I'm thinking double sided tape. But no matter what you use, you may want to consider that you may want or have to remove it someday.
toypusher
Images: 324
Postby Arne » Wed Dec 17, 2008 4:56 pm
I've never seen that stuff without the double sticky tape installed on it already.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby toypusher » Wed Dec 17, 2008 5:08 pm
Arne wrote:I've never seen that stuff without the double sticky tape installed on it already.
You can get it in different sizes at the box stores with the stick already on.
toypusher
Images: 324
Postby planovet » Wed Dec 17, 2008 5:57 pm
I got it at McMaster and it came with a plain back. That was the only way I found for the size I wanted (3/8"x3/8"). There were other sizes that had the adhesive back but not in that size. I thought about using Grant's but it was 1/2" wide and I was looking for a tad smaller.
I'm thinking a double sided tape would be best. If I glued it down it would be a bitch to remove if I ever had to. I guess I need to fine a good quality tape to use. I'm sure I'm going to have to trim it down to get 3/8".
ImageMark (& Cindi)
planovet
The Cat Man
Postby Boodro » Wed Dec 17, 2008 10:25 pm
Ya might try some of that new Gorilla tape. Have not used it or seen it myself, maybe some else out there??? ;) ;)
We are all travelers in this world , from the sweet grass to the packin house , birth till death , we travel between the eternities . ( Robert Duvall as Prentiss Ritter)
Boodro
Images: 101
