OK, AC electrical is not my cup of tea, add to that this GFCI stuff and I'm a bit confused. DC is no problem, played with it a lot when I used to install car stereo.
In the example below, the GFCI outlets #1 & #2 are hooked up to the "line" side and will operate independently. If one trips, it will not affect the other.
The regular outlets #3  are hooked from the "load" side and will trip the GFCI #2 if there is a problem. The ground (green) is not hooked up to anything at all.
Is this correct? I'm not positive<-- if this is how it is supposed to be.
