Frames and Skeletons
Postby Alaskabear99687 » Fri Dec 26, 2008 4:01 pm
Hello, we purchased a trailer last fall and have decided that it will not fit our needs so we are planning on having a trailer built to our specs ($1000-$1500) Question about the trailer would be; should I get an open frame and build a wood floor or have the maker put down an aluminum floor then just glue down som vynal for the floor?
Next is the cabin frame (skeleton) I know that most use wood but I was wondering about using the 1" square metal tubing and bending it to the necissary shapes. You could also put in the necissary gusseting and supports for handles and hinges then attach your skin of choice.
Alaskabear99687
Postby WarPony » Fri Dec 26, 2008 8:02 pm
AB, what kind of camper are you planning to build?
Jeff
WarPony
Images: 289
tctt
Postby Alaskabear99687 » Fri Dec 26, 2008 8:55 pm
I am looking at your basic 5x8 Benroy style. Nothing super fancy but comfortable.
Alaskabear99687
Postby doug hodder » Fri Dec 26, 2008 9:08 pm
AK Bear...I'd love to do the tubing thing for the walls, welding isn't the issue, but I don't have the equipment to roll it and outside of frames I'm more geared to wood construction in my shop. If you have access to it at a reasonable price and can do the welding on it, I'd say go for it. I know the 5 wide guys (No. Cal) build all of theirs in rolled tube and they have some outstanding builds! Doug
Postby Big DE » Fri Dec 26, 2008 10:04 pm
AB
Take a look at mine I think it is what you are talkin about, but be sure to plan it all the way through and dont skin it until you are positive you have all the gussets and tabs in place.
Big DE
Big DE
Images: 93
Postby doug hodder » Fri Dec 26, 2008 11:08 pm
Excellent example Big DE! Doug :thumbsup:
Postby wannabefree » Sat Dec 27, 2008 12:10 am
AKbear -
Must be cold up there. I think you would want a well insulated floor! Somehow vinyl on aluminum sounds a bit cold.
Re: the frame. I wouldn't be afraid of wood framing. If you have to pay a welder to build a frame like Big DE's you'll spend a small fortune. If you can do it yourself and are good with a torch you might be ahead, but not by a lot. I just put the spars on my build and if you pull on a spar you move the whole trailer. I have sandwich walls, 1/4 - 3/4 - 1/8 and 1x2 spars. This thing is rigid, and the roof skin isn't on yet.
-- Antoine de Saint-Exupery
wannabefree
Images: 82
tubing
Postby Alaskabear99687 » Sat Dec 27, 2008 2:44 am
Yep that tubing is exactly what I am talking about. Of course mine will be on a 5x8 but that's it. I noticed your shop, WOW. What is the skin?
Alaskabear99687
Postby Big DE » Sat Dec 27, 2008 10:24 am
well I wish that was my shop it is actually my father in laws shop. The skin is .040 aluminum and I didnt run any kind of conduit for the wiring i used anti-shorts. You can get them at an electrical supplier and just drill holes thru the frame or wire everything from underneath and just go straight up thru the wall where ever you want a light or plug. I did build the frame my self and HD sells a 110v welder that will do the job just fine.
Big DE
Big DE
Images: 93
Postby mechmagcn » Sat Dec 27, 2008 4:37 pm
You can also check out my gallery for pics of a steel tubing frame. My main problem was trying to find someone who could "roll" the tubing. There is no one in my area who does this. I ended up rolling the large radius around a 48" turf tire on a small tractor and the smaller radius around a truck tire.
Jeff & Micki
53 F100
Mercedes turbo diesel
Teardrop "finished" as if they ever are
You can never be lost if you don't care where you are going!
mechmagcn
Images: 56
Postby Keith » Sun Jan 04, 2009 3:16 pm
Here's a link to our most recent build of Ross's trailer. http://www.flickr.com/photos/five_wide_club/sets/72157606232328753/
If you can find someone with a ring roller in your area it doesn't take long to bend everything up.
You might want to check out Sumner Patterson's build. I believe he built a side template and used flat strap for the sides. Here's his web link. http://purplesagetradingpost.com/sumner/teardrop/teardrophomepage.html
Keith
Keith
Images: 5
