My next tear will be only 40" wide and 72" long. I have been kicking around the thought of using an 1 3/8 hollow core door, 36 inches wide, for the floor. I can simply add a 2" x 1 3/8 wood filler on each side, cut the door down to 72" long and insert a filler within the end to add structural strength to it so the roof plywood can be secured to it. This will be secured to the frame with through-bolts and panel adhesive.
I believe it will surely be strong enough, since we never stand on our beds, just lay flat on them. I thought I would coat the bottom with roofing mastic, along with all of the HF frame members. Anyone have any thoughts on this idea, either pro or con, let me know. I just want to keep it light, hopefully less than 400 lb and cheap, less then 200 bucks, plus the 200 dollar trailer.
Roly Nelson, just have to build another, one just isn't enough. "Where are you going to keep it, " she said. I told her to just watch, that is why I am going to call it the 1/4 Nelson Stacker.
