Looking good your moving right along I cant tell from the pictures did you weld the spring support to the frame?
bbarry wrote:1) Thoughts on latest design?
The slideout galley is nice; however, you may want to check your interior measurements to be sure your bulkhead (assuming you are planning on having one) will leave you with the depth for the mattress.
Have you thought about a 10-foot length? The reason I ask is that Andrew already has the profile curves plotted for the trailer-for-two in the design library. Also, 4' x 10' plywood can be found fairly easily, so if you're paying for the materials, you might as well use them.
bbarry wrote:Perhaps I could paint them black and mount a baby moon on them?
Or, you could do what surveytech did with his wheels:
If my memory serves me right (no real guarantees, there ... ...), Ford Pinto and Ford Maverick and Ford Falcons all had 4 on 4" bolt patterns (well, not the ones with V-8s in 'em!), and I'm pretty sure Falcons and some of the Mavericks had 14" wheels. Check those guys out, if you can.
don't diss the original design on the Trailer 4 Two profile. Bandages on the shins are in keeping with the authentic vintage appearance! I've built 3 on that basic profile and in all honestly...haven't drawn blood on them! A slider on the stove and the cooler is a big +. Doug
