by An Ol Timer » Sun Jul 24, 2005 12:06 pm
Ken,
You may want to look at Steve Frederick's site. I believe he did a lot of his build as I did mine. I'm older and a bit arthritic and with double knee replacements, so I wanted to do as much as possible at bench level and horizontal. I built the floor first. Then I did the sidewalls on the bench, completely, even down to the finishing and wiring. The outer skin of the sidewall was the shape of the profile, but the inner frames and the inner skin was reduced by the thickness of the roof spars and the inner ceiling panel leaving a ledge for the ceiling panel to sit on. I finished the ceiling panel prior to installing it. At this point I wired the ceiling and insulated it and then put the outer roof panel on. This let me do all my wiring and finishing without having to crawl around inside of the trailer. The galley and cabin cabinets were done as a unit and then put in place thru the hatch opening. This allowed them to be done on the bench also. I did probably less than 2% of the work from the inside, just touch up and some fixtures. Hope this is of some help.
