Nitetimes wrote:I've got a bar lite on mine plus turn signals on my fenders. Just so the dummies don't have any excuses.![]()
Tail Lites
aggie79 wrote:My teardrop will be wider than 80". I don't plan on putting the "extra" lights but will pre-wire just in case. If needed, the 3-light bar will be above the hurricane hinge.
wlooper89 wrote:aggie79 wrote:My teardrop will be wider than 80". I don't plan on putting the "extra" lights but will pre-wire just in case. If needed, the 3-light bar will be above the hurricane hinge.
That sounds like a good plan, centered above the galley door hinge. There would not be any potential argument about them not being as high as practicable. There is not a rearward facing surface but some sort of mount could be made. Maybe like a very small spoiler or teardrop shape. I would need to add wires to the area but that should be relatively easy inside the cabinets.
Bill
Nitetimes wrote:Something to consider...you also want them as far back as possible. It doesn't do any good if someone stops before they hit your bar lite if it's 4' in front of the back of your trailer!!![]()
And high is not necessarily good, I don't know about most people but I know myself I rarely notice that 3rd eye on a lot of vehicles when it is mounted up high. People tend to focus on the location of your tail lites. So that's where you want to keep as much of your lite as possible.
Just some observations from an old trailer building veteran.
wlooper89 wrote:... There is not a rearward facing surface but some sort of mount could be made. Maybe like a very small spoiler or teardrop shape. I would need to add wires to the area but that should be relatively easy inside the cabinets.
Bill
