Opinions needed on Hatch Ribs
Postby stomperxj » Thu Jan 15, 2009 9:08 pm
I have decided to go with wood for the hatch frame instead of steel tubing for a few various reasons and that has brought up a question:
Which is better?
Hatch ribs from 3/4" ACX plywood or buying some 1x8s and use solid wood and if solid wood, what kind?
My ribs are going to be about 30" or so overall length and 1 1/2" deep.
What say you?
stomperxj
Postby Greg M » Thu Jan 15, 2009 9:17 pm
I vote for plywood. It's strongest in that dimension. There's no worry about the end grain tearing out because anything attached (ie: the outer skin)to it will likely not be subjected to a lot of force.
-Greg
Greg M
*Geek Extraordinaire
Images: 85
Postby Boodro » Thu Jan 15, 2009 9:18 pm
Hi , a few things to think about.Solid wood can warp & twist , Plywood is not as susceptible . If I went with solid I would use poplar , it is a stable wood. You may want to double up on them also, what I mean is cut 2 & glue & screw them together. It will help with spring back & warping. I used 3/4 inch ply & glued 2 together & they are VERY strong.Never had any spring back or warping. Good luck!! :thumbsup: :thumbsup:
We are all travelers in this world , from the sweet grass to the packin house , birth till death , we travel between the eternities . ( Robert Duvall as Prentiss Ritter)
Boodro
Images: 101
Postby Elumia » Thu Jan 15, 2009 11:08 pm
I'd say it depends on how you plan to attach everything. Can't reliably use screws or other mechanical fasteners in the edge of plywood like you can with solid wood. You could use Poplar and join two pieces with biscuits to make your dogleg, less expensive than a big piece of stock. You could use a combination of solid wood and plywood.
Mark
Elumia
Images: 15
Postby madjack » Thu Jan 15, 2009 11:24 pm
...no pics handy but on the 5wide, we used 3/4x2.5" ply ribs(13ply birch/poplar cabinet grade)...1x2.5" oak for top/bottom boards...skinned with 1/8th luan ply and .040 AL...living plastic piano hinge...no other bracing/blocking...weighs about 30 pounds...easy to lift...works ever so well for me(and wife)...........
madjack 8)
Postby stomperxj » Thu Jan 15, 2009 11:59 pm
Alright guys... thanks for the input. Plywood it is. I have a ton of scrap 3/4 so i guess some of it will get used...
Now all i need is for it to warm up a little... 8)
stomperxj
Postby MOKI SEAKER » Sat Jan 17, 2009 2:16 pm
I planed some Ash down to 1/8" and laminated my bows. Stronger than ply, and less chance of breakage with the grain. You could cut them down, to 1/8" on a table saw, instead of using a planer. Jim G :)
Mark Twain
MOKI SEAKER
Images: 41
Postby mikeschn » Sat Jan 17, 2009 2:41 pm
I see I am a little late to the question, but you made a good call.
Plywood is very strong and stable in that orientation, and the more plies, the better.
On my last build, the Giant Teardrop (aka the Generic ET) I glued the two outside ribs together... Worked perfectly!
Postby TinKicker » Sat Jan 17, 2009 4:20 pm
I KNOW a tear is always greater than the sum of it's parts, but after all the reading I've done here (on the entire site) on all the little bits and pieces that make a complete trailer, it reminds me of when I read somewhere the exact number of parts it took to build a 1957 Chevy Belair. Several thousand. That's how I feel about what I'm getting into. But I gotta' remember...one piece at a time. :)
Kelsey
__________
Go ahead and get your project started because it's just like having kids...if you wait to start until you're skilled enough or rich enough, you'll never do it. And just look at what you'd miss!
__________
In planning any project you've never attempted before, always allow for the three three's: It will take you three times longer, three times more material, and three times more money than you thought.
TinKicker
Images: 11
