What do you do with exterior screws.
Postby Mark » Thu Jul 28, 2005 11:43 am
Do you dip your exterior screws in Lock Tite or silicone prior to installing them to keep water out and from loosing?
Mark
Postby emiller » Thu Jul 28, 2005 1:11 pm
8) I used heavy duty contruction liqiud nails then put wood putty and sand then paint a couple of coats of kilz the add a couple of coats of exterior house paint.
emiller
Images: 157
Postby Mark » Thu Jul 28, 2005 1:13 pm
I'm sorry, I should of said that I am putting them into aluminum trim.
Mark
Postby madjack » Thu Jul 28, 2005 1:23 pm
...put a dab of waterproof caulk on screw hole prior to inserting screw
madjack 8)
Postby SteveH » Thu Jul 28, 2005 1:42 pm
I used a dab of aluminum colored silicone under my exterior screws.
SteveH
SteveH
Images: 42
Postby Mark » Thu Jul 28, 2005 1:46 pm
I have some. How did you apply it? Did you try to force it into the hole or dip the screw into? Thanks
Mark
Postby IraRat » Thu Jul 28, 2005 1:51 pm
Ahhh--the caulk versus silicon controversy continues...
Kind of like the Civil War, pitting brother against and brother and tearing families apart.
I'm going with caulk, because it's a much funnier sounding word than "silicon."
However, they sell silicon caulk TOO, so what the heck is THAT all about?
--Ira
IraRat
Forum Storyteller
Postby s4son » Thu Jul 28, 2005 2:24 pm
Ira,
Silicon caulk is for people that can't decide.
Scott
Are we there yet?
s4son
Images: 180
Postby ceebe » Thu Jul 28, 2005 6:44 pm
Hey Rat!
I thought it was "The War of Northern Agression"?
Oh yeah, i forgot, you're a carpetbagger
ceebe
Postby ceebe » Thu Jul 28, 2005 6:48 pm
but seriously, when i have to use screws in a glider trailer repair, i use a bit o silicone and then i use thin nylon washers under the screw head. They seal nicely and allow a little monement of the aluminum under the screw head. :D
ceebe
Postby Denny Unfried » Thu Jul 28, 2005 7:53 pm
I installed all of my trim twice. First time to fit then it all came off. I then put silicone calk on the trim underside and into all the screw holes then reinstalled the trim. One exception was the piece that runs along the bottom side just in case some moisture gets behind the aluminum is has someplace to go.
Denny
aka - "Uncle Denny"
<img src="http://www.uncledennyscorner.com/teardrop/photos/Linux.gif">
Denny Unfried
sprint car builder/racer & all that jazz
Postby madjack » Thu Jul 28, 2005 8:46 pm
ceebe wrote:Hey Rat!
...for all those of yankee descent...it is "THE WAR OF NORTHERN AGGRESSION'"
(no offense meant, I mean it has been 140 years(yea, right))
FORGET...HELL
madjack 8)
Postby Cutterpup » Fri Jul 29, 2005 7:45 am
Not that I was there or even care what happened 140 years ago, but the winner gets to say what the name of the war or the battle was.
Dan
Cutterpup
Images: 15
Postby SteveH » Fri Jul 29, 2005 8:07 am
Mark wrote:I have some. How did you apply it? Did you try to force it into the hole or dip the screw into? Thanks
Mark,
To get back to the subject, and try to answer your question, I just put a dab of silicone under the head of the screw and then put it into the hole. The turning action of the screw against the aluminum as it tightens will spread the silicone evenly under the joint.
SteveH
SteveH
Images: 42
Postby IraRat » Fri Jul 29, 2005 8:55 am
Hey! You guys took Fort Sumtner! (Spelling?)
What did they use do seal their screws back then?
Anyway, I don't care. Whatever side I was "on," I would have gone to Canada.
--Ira
IraRat
Forum Storyteller
