Epoxy Paint
Epoxy Paint
Postby Dee Bee » Tue Aug 03, 2004 11:31 am
Has anyone seen the expoy paint made by Rustolium? It just arrived at my local True Value hardware store. Has anyone used it or considered using it for exterior ply application on a TD?
DEE
Grace happens...
Dee Bee
Images: 55
Postby mikeschn » Tue Aug 03, 2004 11:51 am
Got a URL where I can read about this? I'd like to compare it to the UniFlex 255 which is used on boat hulls. That what I put on the Baja Benroy. The UniFlex 255 is great stuff, and with the right roller, it went on nice too! I would definitely use it again!
You can buy it here...
http://www.rotdoctor.com/poly/polymain.html
P.S. Just a happy customer!
Postby asianflava » Tue Aug 03, 2004 1:23 pm
Is that the same 2 part epoxy paint they sell for garage floors?
asianflava
Postby JamesW » Tue Aug 03, 2004 4:51 pm
Mike,
What was covering the Baja Benroy before you painted it? Did you skin it with aluminum first then paint or did you just use the plywood walls?
JamesW
Postby mikeschn » Tue Aug 03, 2004 5:20 pm
I just painted right on the wood. The edges were soaked with CPES clear penetrating epoxy sealer.
Postby Larry Messaros » Tue Aug 03, 2004 6:56 pm
mikeschn wrote:I just painted right on the wood. The edges were soaked with CPES clear penetrating epoxy sealer.
Mike
How smooth did it lay down? How many coats?
Now that you have had it on for a while, how is it standing up? Is there any cracking of the finish? How are the edges holding up? Any rock chips?...................
I'm sure I'll think of some more questions! :D
Larry Messaros
:snow
Cariboo Country: If you don't like the weather, wait 5 minutes!
Larry Messaros
Floor Paint
Postby Dee Bee » Tue Aug 03, 2004 7:04 pm
asianflava wrote:Is that the same 2 part epoxy paint they sell for garage floors?
It is in the same product line. But one Version that I am interested in idoes not has the color "flecks" embeded in the paint. It comes in true white.
Dee [/b]
Grace happens...
Dee Bee
Images: 55
Postby JamesW » Tue Aug 03, 2004 8:37 pm
Thanks Mike. What type of roller did you use?
JamesW
Re: Floor Paint
Postby asianflava » Wed Aug 04, 2004 2:26 am
Dee Bee wrote:It is in the same product line. But one Version that I am interested in idoes not has the color "flecks" embeded in the paint. It comes in true white.
Dee [/b]
The garage stuff comes with a bag of "flecks". It is an option wether you want to put them on or not. You are supposed to sprinkle them on when you are finished painting but before the paint dries. Although, I haven't seen the stuff that you mentioned. Maybe you can compare them and see which one is cheaper, I think the garage is only available in gray. The garage kit makes one gallon when mixed up.
asianflava
Postby mikeschn » Wed Aug 04, 2004 3:28 am
JamesW wrote:Thanks Mike. What type of roller did you use?
It was the pink roller from home depot with a real short nap...
P.S. You'll notice it says "moisture and solvent resistant core"!
