Cliff starts a Grasshopper / Weekender!
Postby Cliffmeister2000 » Wed Jan 21, 2009 1:57 pm
Well, as it turns out, I didn't leave enough room for weatherstripping around the doors.
I tried something from HD, and it should have worked, but couldn't fasten it.
It looked promising, too!
But, it kept shifting. So, I pulled the door jambs off
I'm gluing 1/4" poplar strips that will be behind the door jamb
When the glue dries sufficiently, I will put the door jambs back on and have 1/4" to put weatherstripping in. Hope it works!
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby planovet » Wed Jan 21, 2009 5:36 pm
Cliffmeister2000 wrote:Well, as it turns out, I didn't leave enough room for weatherstripping around the doors. I'm gluing 1/4" poplar strips that will be behind the door jamb. When the glue dries sufficiently, I will put the door jambs back on and have 1/4" to put weatherstripping in. Hope it works!
It should work. I almost did the exact same thing but caught it before I glued my door frames on. Glad I did because I epoxied my frames on and to remove them would have been difficult without tearing up the interior. Anyway, I glued a 1/4" strip in like you and used a 3/8" weatherstrip to finish. Worked great.
Spacer glued in:
Frame glued on:
ImageMark (& Cindi)
planovet
The Cat Man
Postby Cliffmeister2000 » Wed Jan 21, 2009 5:45 pm
Thanks, Mark! Your photos didn't come through, but I got the picture. Your post solved another dillema. I wanted to use 3/8" weatherstripping. Now I know it will work! I really appreciate it!
[Edit] Huh. The photos are there now! go figure. :?
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
Cliffmeister2000
Images: 157
Postby Cliffmeister2000 » Wed Jan 21, 2009 5:51 pm
planovet wrote:
Mark, what is the white fuzzy stuff in this picture?
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
Cliffmeister2000
Images: 157
Postby Cliffmeister2000 » Tue Jan 27, 2009 5:38 pm
Well, today I used my home built router table to make my very first cabinet door! A weak attempt at best! Still, there is some satisfaction in having narrowed the fear factor to a manageable level!
This door is made from cull lumber from HD. $0.51 each, 1x6 lumber 48" long. $19 worth of Aracua 1/4" ply.
Hummm... Panel needs to be 1/4" narrower and shorter!
Home built router table, with Chinese 1/2 plunge router installed.
Original plan was to make these of poplar. However, due to continued unemplyment, cull pine seems a reasonable alternative for now.
Router set for the stiles and rails came from Harbor Freight. Not recommended.
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
Cliffmeister2000
Images: 157
Postby planovet » Mon Feb 02, 2009 4:41 pm
Cliffmeister2000 wrote:Mark, what is the white fuzzy stuff in this picture?
Sorry it took so long to reply, I was on vacation 8)
The "white fuzzy stuff" is a carpet-like hulliner that I put on the walls. I did not want to be surrounded by wood and wanted something to dampen the noise. It went on with spray adhesive and looks great. You can get it here.
ImageMark (& Cindi)
planovet
The Cat Man
Postby Cliffmeister2000 » Mon Feb 02, 2009 5:41 pm
Nice! How easily does it clean? I imagine if it is used in boats, it must be pretty durable. :thinking:
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
Cliffmeister2000
Images: 157
Postby planovet » Tue Feb 03, 2009 11:21 am
Cliffmeister2000 wrote:Nice! How easily does it clean? I imagine if it is used in boats, it must be pretty durable.
It seems to be real durable. I haven't gotten it dirty yet so I don't know how well it cleans up. You can vacuum it just like regular carpet.
ImageMark (& Cindi)
planovet
The Cat Man
Postby Cliffmeister2000 » Mon Mar 09, 2009 5:33 pm
It's been a while since I posted, primarily because life has been interfering with my teardrop work as well as my camping. This last weekend I was all set to go the the Arizona Tearjerkers' Spring Clean. Wife and dog got sick. Couldn't go.
So, in an effort to redeem the time, I built my side table. :D
Had to make a clamp extender,
Pine, wraped in redwood.
2 coats of polyurethane so far,
Last edited by Cliffmeister2000 on Tue Aug 10, 2010 6:22 pm, edited 1 time in total.
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
Cliffmeister2000
Images: 157
building
Postby dandan » Mon Mar 09, 2009 5:37 pm
it looks like you are as much stuck for space as me !
:lol:
keep up the good work.
dan. :thumbsup:
Nostalgia's not what it used to be !!!
dandan
Roswell Club
Images: 214
Re: building
Postby Cliffmeister2000 » Mon Mar 09, 2009 5:41 pm
dandan wrote:it looks like you are as much stuck for space as me !
:lol:
dan. :thumbsup:
I have a modern 3 car garage, which means I could park my wife's Mazda3 in there 3 times! :?
As it is, she insists on parking in the garage, and so I use her space when she's at work, as my space is full of trailer! :lol:
The worst part is, she make me clean her side so she can park again every night! :roll:
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
Cliffmeister2000
Images: 157
Postby Cliffmeister2000 » Mon May 25, 2009 6:45 pm
My beloved decided my trailer was a bit on the boring side. So, she painted some (stripes? Wedges?) along both sides, then pinstriped the edges. I think it looks pretty good! She certainly matched the truck red pretty well!
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
Cliffmeister2000
Images: 157
Postby mikeschn » Mon May 25, 2009 7:11 pm
Can you tell me more about the spray adhesive you used? Brand? Did you have to coat both the wall and the liner, or just the wall?
Mike..
Postby Miriam C. » Mon May 25, 2009 8:44 pm
:applause: :thumbsup: Image
Cliff you beloved did a fantastic job. Love the stripe. :thumbsup:
:oops: Cut and paste doesn't always work and should be previewed. :D
Postby Cliffmeister2000 » Mon May 25, 2009 8:59 pm
Thanks, Miriam!
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
Cliffmeister2000
Images: 157
