Quick HELP needed
Quick HELP needed
Postby Guy » Tue Aug 02, 2005 4:56 pm
Dear All,
I am still demolishing the teardrop4vets frame. I came across a type of fastener I know nothing about and have to remove quickly.
It is sort of a rolled up piece of metal used in a similar way to a cotter pin.
connects a rod inside a tube.
How do I get it out?
Regards,
Guy
Guy
Images: 44
Postby toypusher » Tue Aug 02, 2005 5:05 pm
Can you tell if it has a split? If so, you should be able to drive it out with a punch or something similar. It is probably just a compression type pin and can be driven out.
Kerry
toypusher
Images: 324
Coiled spring pin
Postby Guy » Tue Aug 02, 2005 5:06 pm
It is a coiled spring pin. Looks like I can bang it thru but I do not know if that is proper
Regards,
Guy
Guy
Images: 44
Postby madjack » Tue Aug 02, 2005 5:12 pm
...like TP said, it sounds like a basic "split pin"...it should just drive out with a punch, small drift pin or whatever you have on hand
madjack 8)
Postby Chuck Craven » Tue Aug 02, 2005 5:17 pm
It is a roll pin. Made of hardened spring steel. You can’t dill it out with out breaking the drill bit. You have to use a punch just a little smaller than the hole the pin is in. If the punch is to small it will go inside the pin and wedge the punch in the pin or break off.
If the punch breaks off you are in trouble. The only thing you can do is use lot of heat to try to take the hardness out of the pin and broken punch and try it again. If what is left is not damaged from the heat. :x
Chuck
Chuck a new td builder
Chuck Craven
Images: 62
Postby purplepickup » Tue Aug 02, 2005 5:23 pm
Guy, it sounds like it's a coiled roll pin and probably looks like this.
Like everyone said, it will just drive out but it's too hard to drill out. If it's rusted in place I sometimes heat things quite hot then put cold water on them. A lot of times it will break loose enough to finish the job with a BFH.
:D
George
purplepickup
Thank you all
Postby Guy » Tue Aug 02, 2005 5:26 pm
Thank you guys.
I wondered if there was a special tool to do the job, but guess not.
Regards,
Guy
Guy
Images: 44
Re: Thank you all
Postby Larwyn » Tue Aug 02, 2005 5:37 pm
Guy wrote:Thank you guys.
Actually I do recall seeing spcial punches for roll pins. They had a sholder to catch the edges of the pin with a short mandrel that fit inside to keep the punch centered. Even if you could find such punches you would have to find one just the right size for your application. I've had good luck driving them flush with a brass drift to prevent deforming the end then finishing up with a punch just smaller than the hole in which the pin fits. Main goal is to not deform the end of the pin that you are driving through the hole (you only get two chances).
Oh and as someone already mentioned a BFH could be useful too.
Larwyn
Larwyn
Mad Kilted Texan
Images: 210
Postby Q » Tue Aug 02, 2005 5:45 pm
The special tool is called a "pin punch". It's just a round, flat ended punch of a slightly smaller diameter than the hole.
Q
Q
a Rolled pin punch
Postby Guy » Tue Aug 02, 2005 6:03 pm
Just when you thought it was safe to go back to work along comes the Google fairy and you find out about a "Rolled pin punch" :lol:
Regards,
Guy
Guy
Images: 44
Postby Larwyn » Tue Aug 02, 2005 6:26 pm
Q wrote:The special tool is called a "pin punch". It's just a round, flat ended punch of a slightly smaller diameter than the hole.
Q
The punch you describe is the one I recomended using. But the roll pin punch I mentioned is a bit different than a standard pin punch. Either will work if used properly.
Pic of "Roll Pin Punch"
Larwyn
Larwyn
Mad Kilted Texan
Images: 210
