keep us posted as it progresses as myself and probably many others are thinking about using the same technigue....
I got interested in it when thinking about building a homemade car, call the Tri-Magnum.... used a motor cycle for rear wheel power supply, with front end from vw? or similar ..... plywood bulkheads with foam sheets and fiberglass covering....
I didn't care much for the motor cycle as power supply and reengineered it to use a single rear wheel, but a front wheel drive vehicle as power supply.....
I good for planning, but most projects rarely get past that point... (genetic flaw.... inherited from my dad.....)
but camper still in planning stage, so it still has a chance....
foam and fiberglass exterior, interior? (still thinking about that..... ) I have a lot of wood trim and components from stripped RV's and conversion vans, and would like to modifiy them into it, make it looks like they belong there, not just thrown in and put to use...
