angib wrote:Adding diagonals to the framework to resist sideways loads is perfectly sensible for a house, but completely unnecessary for a trailer where the skin is bonded on properly.
<snip>
And you can't get an example of skins that are better bonded-on than Bruce's. How come you have a vacuum pump at home, Bruce, or are you using a shop vac? (I've never had the confidence to try that, as I assume it'll burn out the vac motor.)
Andrew
Juneaudave wrote:Wow Bruce...your putting us all to shame!!! Glad you are back at it...we were really enjoying the build and learning alot from your techniques!!!!
Steve Frederick wrote:Wow!
What a great build!![]()
What about the vac bag? Poly, rolled and sealed?
Looking terrific!
GPW wrote:Done a lot of vacuum bagging in the past on model airplane projects.... a real vacuum pump makes all the difference, giving tremendous clamping pressure to parts... much better than a Hoover... Just FYI..
bdosborn wrote:GPW wrote:Done a lot of vacuum bagging in the past on model airplane projects.... a real vacuum pump makes all the difference, giving tremendous clamping pressure to parts... much better than a Hoover... Just FYI..
Do you have a link to a good vacuum pump? The ones I came across for something this size where pretty spendy...
Thanks,
