Actually I found 50 of them. I was looking around Craigslist for something else and stumbled across an ad for some military surplus axles. They come with the axle, hubs, wheels and tires. The ad listed $60, but when I emailed him he said $50 would be fine.
Sorry, but I don't have a pic. The ad expired and I didn't save the photo. I know a post like this is pretty worthless ithout a pic and I will try and get one.
Now for the not so good part. The axle is a 1000 pound rating and that means a lightweight build for sure. The axle is also way too short. It must have carried something small because it's only 29 inches center to center on the mounting brackets. Clearly to be usable it would either have to be cut into two half axles or extended with a new center section. Is this realistic? Can an axle be modified like this? Since it's so small I'm guessing that the rubber pieces would have to be removed before welding. Is that easy to do on most torsion axles?
At only $50 I will likely pick one up. Just the rims should be worth that much. The tires looked pretty big. Maybe even 15 inch rims, but it was hard to tell. If anyone else is interested in one, they are located in Palmdale or Lancaster California.
How wrong can you go for $50?
Thanks in advance for any comments.
Carl
S
