Has anyone used them?
Any design ideas for one?
Here is what the one I saw looks like:
jackdaw wrote:...However if the heater in the photo is used outside the tent or trailer, and has a heat exchanger above the burner, and a 12 volt fan to blow the clean heated air into the tent or trailer, It should be safe.
I haven't seen a heater like it before, but i can see the 12v leads and I assume that's the way it works...
Sealed heat exchanger keeps dangerous gases outside tent.
No longer available at this time
All three of the Hot Vent tent heaters show a "No longer available at this time" message... have they been discontinued?
Hello Brian,
Zodi is working on the 4th generation Hot Vent HP and first generation Hot Vent X-40 Outfitter Heaters. These products are not available at this time and expected to be released at an unspecified future date. A press release will announce the availability of the products. If you would like an email notification when the Zodi Hot Vent HP and Hot Vent X-40 Outfitter heaters are available, please reply with the email address to send the notification to.
Thank you,
Customer Service
Zodi Outback Gear
Ph: 800-589-2849
Int'l Ph: 801-255-6418
website: www.zodi.com
10,000 BTU will heat 4-6 person tent in under 10 minutes
andHot Vent is NOT intended to be operated during sleeping periods.
Do not operate unattended. Hot Vent designed for temporary heating only. Do not sleep with Hot Vent operating.
Senior Ninja wrote:Hi,
For what it's worth, I have four inches of insulation under a four inch thick mattress with an inch of foam insulation in both the walls and ceiling. We use an opened sleeping bag as a blanket and have never been cold. Usually I kick off the sleeping bag and open a window. You may need the heater for a few minutes to warm up the interior, but I can't believe you'll need it all night. Well insulated tears are warm and cozy, especially when ocupied by two loving individuals.
