doug hodder wrote:Cliffmeister2000 wrote: Is the issue on the jon boat the water displacement, or the aluminum? I'm actually thinking of something I could put a trolling motor on, and carry on the pickup in front of the weekender.
Cliff....I've built a couple of boats but am by no means an expert on any of it. My opinion...you need displacement. The easiest way to get maximum displacement in a small boat with a minimum of effort and cost is to do a flat bottomed one as opposed to a V hull. Easier to build also. If you want to just putt around and fish it'll work. If you go with aluminum. Battens to support your footing will work. I've built a kinetics vehicle that held 6 people and only used .050 aluminum skin on it all. I'm betting that you could build a skiff that could be lifted onto a roof rack that would support you and your other in 1/4" ply. Also might try www.glen-L.com great bunch of people over there that are willing to help out. I've built a couple of their designs...worked out great!
Now I see you aren't planning on building....so none of it matters. Doug
Cliffmeister2000 wrote:Thanks, Darkhorse. I like the 12 footer, FL12. Seems like something I could handle. No weight capacity given, however. Bearmountain has one that has a stated weight of 847 lbs, far exceeding my requirements, but I'm terribly intimidated by the cedar strip construction.
Canoe is also a possibility, albeit without a motor.
Thanks, you've given me a starting point.
Tinksdad, I found several references to the 4dink on Google, and they pointed me back to the Bateau company, but no reference to it there. I wonder if it has been discontinued?
BobR wrote:Here is a link for the one-sheet skiff if you want to try building a boat on the cheap!
http://www3.sympatico.ca/herbert.mcleod/skiff.htm
Miriam C. wrote:
Picture stolen from http://www3.sympatico.ca/herbert.mcleod/skiff.htm
Gotta love it!
Miriam C. wrote::D
You know you just gotta be desperate!
Mary K wrote:Take a look see at these Gator Boats. The plans are cheap. I purchased the Dragonfly plans...I just haven't made the time to build it.![]()
Gator Boats
They even have a nice little forum, like here, for their builders.
