Heres the trailer
I am not sure how wide it is going to be. I know that I want it 8 feet long and Im limited to 4 feet high. I will handle the width once i get the trailer broken down. I dont want or need a hatch. I would like to have everything i can possible fit into it. TV, lighting, fan, and ac are a few of the things. Im trying to do this as cheaply as possible, I may use the windows of the travel trailer but they are sooooo damn ugly. I also want to build it light enough to be towed by the jeep so under 1500 lbs. I am also goign to lift it and run 31's tires on it. I will see about an axel swap after the trailer is broken down. I am not going to use it in any kind of off road situation but would like for it to look like it matches the jeep. I am thinking of finishing it in herculiner and painting it white. I have seen this stuff used in jeeps and its water proof and pretty damn strong. If you have any suggestions or ideas for me please feel free to ask. Over the next few weeks ill be posting up different ideas that i have and ill sort through them. Id like to finalize the plans in two to three weeks soooo i can hit the ground running. I am drawing mostly from steve fs off road tear and this one http://expeditionportal.com/forum/showt ... 44&page=13. I dont want to build out over the tires unless the area between them is way to small. Id like it to be five feet or a little more. What do you all think jsut by looking at the trailer? how big of a trailer (space between tires) am I gonna have?
Id appreciate and input or ideas you all can give. Im on a tight budget and my skills are limited.
Heres a picture of my tow vehicle, was thinking maybe of painting the same red, itll be a smaller trailer so im not sure i itll be too gaudy with all that red
This is a great site with a great group of people I thank you in advance for all the help Ill get!
