Since I don't know anything about electrical hook ups, please answer in small words and be kind if this is a stupid question.
Thanks so much,
Lisa
lisasweetie wrote:Alright, I plan to go get my Silver Shadow in a few weeks and need to install my trailer hitch and wiring. I actually have a friend doing the install, but my question is..... They tell me I need a 7 round connection, and I'm not sure where to get that. I've looked online and found an adapter that converts a 4 flat to a 7 round. Is that what I need??? It seems unnecessary, can't you buy a wiring package that gets you to 7 round to start with????
Thanks so much,
Lisa
Nobody wrote:Lisa, dunno which Hyundai you have but I installed the hitch receiver & wiring on my wife's 2003 Santa Fe by myself. If your friend is at all 'handy' & has a modicum of tools, it's a snap. I used this receiver - http://www.etrailer.com/pc-H~V82241.htm ... d=20037066 - which fits 2001 thru 2006 Santa Fe, & this wiring harness - http://www.etrailer.com/pc-VWH~118310.h ... d=20037066 - which fits the same years Santa Fe. It uses a 4-flat plug but as far as I've been able to find there's no 7-pin wiring harness made for the Santa Fe. If you need a charging wire or other power source, I'm pretty sure additional wires could be run & a 7-pin receptacle could be fitted in place of the 4-flat, otherwise, just use the 4-flat to 7-pin adapter. I'm not a total novice at either auto/trailer wiring or mechanical so it took me a couple of hours to install the hitch receiver & probably another couple of hours to install the wiring harness (mainly because I had to actually 'disassemble' a couple of inner panels to 'plug-in' the wiring). The website listed also has links to downloadable instructions for installing both items that were of great help to me. There's another wiring harness - http://www.etrailer.com/p-118473.htm - that's about$20 more expensive but says it has an 'Upgraded Circuit Protector' & specifically mentions that it can be used with 5-pole, 6-pole, or 7-pole adapters. Dunno if that's worth it or not but if I'd seen it when I ordered I'd probably have gotten it.
