Wood for bending?
Wood for bending?
Postby TheOtherSean » Wed Feb 18, 2009 7:11 pm
I'm considering building a teardrop or TTT using bent & laminated wood strips to make the curved frame. Unfortunately, the local Home Depots only carry lattice in stain-grade, and that's 47 cents per linear foot for the 1/4 inch thick by 1-1/8 inch wide strips. Does anybody know of a more affordable source of lattice-type wood strips?
TheOtherSean
Images: 111
Postby Dark Horse » Wed Feb 18, 2009 7:33 pm
Most lattice wood is not worth your time. The thickness is nice and that about it, unless your willing to spend quite a bit of $
If you have or have access to a tablesaw you can rip your own stock down for laminating.
Or
set up a strip jig and use a circular saw to rip strips from your stock
http://www.home.earthlink.net/~durgerian/id5.html
They do an very nice job, I don't care for the hand placement in one pic, Fingers should never be below the plate. other than that the set up they use works very well.
I like anything that turns money into noise.
Dark Horse
Postby Steve_Cox » Wed Feb 18, 2009 8:38 pm
I ripped clear, hand picked 2 X 4 studs to make laminated curved spars. Also have made them from strips of 5.2 mm plywood for spars that are not exposed (inside walls)
Steve_Cox
Images: 196
Postby bfitz » Wed Feb 18, 2009 9:30 pm
I'd recommend looking at 2x10 or 12's. Usually they are a better grade (fewer knot holes/warping, etc) and will make for higher quality strips. While one 2x10 is much more expensive than a 2x4, I don't think the board-foot cost is that much higher. Combine that with higher quality and it's well worth it!
bfitz
Images: 22
Postby TheOtherSean » Wed Feb 18, 2009 9:51 pm
Thanks for all the advice so far. Based upon what I've seen so far, I'll plan on ripping solid wood (2xwhatever) down to make the strips. Thanks!
TheOtherSean
Images: 111
Postby angib » Thu Feb 19, 2009 6:10 am
It might be worth asking if a bent laminated frame is necessary?
It appears to me that some teardrop builders think they are building a house where a self-supporting framework is built first and then skinned in with plywood to keep the weather out.
In a teardrop, the plywood does all the supporting and the framework is just there to hold the plywood flat and to make it easy to join the corners. If a framework is built first, and can hold itself up, then it's way overbuilt.
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby TinKicker » Thu Feb 19, 2009 4:37 pm
Thank you for saying that again Andrew. My long-indoctrinated brain is slowly absorbing the mantra "self-supporting monocoque", and your repetition is helping so much. The more you say it, the lighter my trailer frame dimensions are getting! :lol:
It's the best diet plan for heavy tears I've found yet. :applause:
Kelsey
__________
Go ahead and get your project started because it's just like having kids...if you wait to start until you're skilled enough or rich enough, you'll never do it. And just look at what you'd miss!
__________
In planning any project you've never attempted before, always allow for the three three's: It will take you three times longer, three times more material, and three times more money than you thought.
TinKicker
Images: 11
Postby TheOtherSean » Thu Feb 19, 2009 10:30 pm
angib wrote:It might be worth asking if a bent laminated frame is necessary?
I'm not sure, but I was leaning towards building the lightweight standy from the March/April 1946 Popular Science, and that's what the instructions for that one called for. It also gives me space for thicker insulation, which is very important -- winter camping is a major design criteria.
Andrew
I was thinking the framework be necessary since I'll be working with multiple sheets of plywood. If I was just building a teardrop, I'd probably be going the plywood frame route, but I've decided a teardrop is just a little too limited.
TheOtherSean
Images: 111
Postby RogHodge » Fri Feb 20, 2009 8:50 am
Your answer is no you do not need to bend/laminate the frame. The plans you are looking at, which I love BTW, also call for a canvas roof- I don’t think you will want to have one of those either.
It sounds like your sides will want to be “sandwiched” with a touch of pre-planning your joints can land on a ‘stud’ and your laughing. Also ply can be “scarfed” like the boat builders do- but I doubt if that is necessary.
http://www.oneoceankayaks.com/stitchglu ... rfjig2.htm
For those who would like to have a look I have a build journal and covet your feedback.
http://www.tnttt.com/viewtopic.php?t=33547
RogHodge
Images: 51
Postby TheOtherSean » Fri Feb 20, 2009 9:45 pm
RogHodge wrote:Your answer is no you do not need to bend/laminate the frame. The plans you are looking at, which I love BTW, also call for a canvas roof- I don’t think you will want to have one of those either.
Thanks for your comments. I was planning to try either vinyl like on old-style automotive roofs, or fiberglass as in the Lil Guy plans.
TheOtherSean
Images: 111
