So I'm guessing...... No then?
Just kiding, I will make separate lines of conduit!! Especially because I am not good at putting the smoke back in electronics once it comes out !!!
wannabefree wrote:Wow! I've just gotta post on this one! I swore off the electrical posts; there are so many expert opinions. But this one I can't resist.
Wires can rub together and insulation wear away whether they carry 110VAC or 12VCD. This is a good reason to run you 110V hot line in a separate conduit from the neutral. And add a third conduit for ground. Plus one for the 12Vplus and and a separate Ground. If you work it right, you can put so much conduit in this trailer you won't need walls!
OK, I apologize for being annoying. My solution was to use good stranded wire with really tough insulation. Ran it wherever I wanted, sometimes 12VDC right next to 110VAC -- and no conduit for any of it. I have fuses and breakers and I will take the chance of blowing out something when the 12V shorts to the 110V, if that ever happens. There are no doubt other solutions just as good; perhaps some better. Mine's good enough for me.
Larwyn wrote:I would even advise calling in an expert if you find that someone has foolishly unplugged the connector between the TD and the tow vehicle. Even though this plug can only be connected one way, you are better safe than sorry.
caseydog wrote:I guess the point I'm trying to make is that we all make mistakes. Now, if you make a plumbing mistake, you can get things wet. If you make an electrical mistake, you might just ruin a light bulb, or you might start a fire, or you might electrocute yourself or someone you care about.
Soooo, with the potential cost of a mistake that high, why not go out of your way to keep things as safe as you possibly can?
If I were going to mix low-voltage DC and 100V-AC in one camper, I would put as much separation as possible into the two systems.
CD
caseydog wrote:I can see someone deciding to alter their TD down the road (something all of us do -- some more than others). They make some changes, re-route some wires, get some wires mixed up, and zap.
I can also see someone trying to make a repair because the wife's reading light isn't working. He's at the campsite, after dark, tired, and perhaps a little cranky about having to fix this now. Zap.
I can easily imagine myself, and many non-electrician friends of mine, making either one of those mistakes.
CD
