cad victory
Want to design your own teardrop or tiny travel trailer. You can do that in 2D or 3D. We keep our secrets in here!
Postby madjack » Sun Aug 14, 2005 4:06 pm
...Mike, the pro version has the fillet cmd and some others and it does offset also...once I figured out how to strike an arc, it all started coming together for me and now it is just a matter of figuring the rest out...I will definetly be going for the pro upgrade. It is a simple program(no 3d modeling) but I noticed in the help section that it will do 2d stuff and a number of tools are added in the pro version...Thanks very much for the compliments, coming from a "CAD master" like yourself makes it all the the better I just wish I would've had this program a year ago( or 10, or 20). I also just figured out how to draw all my lumber dimensionally so now I can do more than just a line drawing...like making an actual blueprint with all of the (accurate) info in place for building. I also have a cut list program for laying out multiple cuts on sheet goods to get your best usage, between the two, well.........what else do you need but a fully equipped shop and a truck load of materials(and some time) :thumbsup:
madjack 8)
Postby toypusher » Sun Aug 14, 2005 4:23 pm
madjack wrote: I also have a cut list program for laying out multiple cuts on sheet goods to get your best usage...)
First let congratulate you on a fast paced learning. I have AutoCAD 2005 and a book for AutoCAD 2002. It makes for pretty boring reading and I'm not sure that I need all the details that it is going into to start with. I also have a copy of CadStd and have not played with it much yet.
Secondly, what is the "cut list program" you have and were did you get it? I seem to spend alot of time when preparing for a project, using a piece of paper and pencil to figure out the cut list. A program would save me alot of time and energy.
Thanks
Kerry
toypusher
Images: 324
Postby Chris C » Sun Aug 14, 2005 4:25 pm
I'm still super-impressed, Madjack! Great stuff! :thumbsup: :thumbsup:
Chris :D
Chris C
Postby madjack » Sun Aug 14, 2005 4:32 pm
...goto www.sheetlayout.com and D/L "SL8 full version"...it has an evaluation version that is free and full featured but limits the number of cuts/sheets you can do at one time...not a problem for smaller projects like we are doing here....and throw that pencil and papre away :lol:
madjack 8)
Postby toypusher » Sun Aug 14, 2005 4:40 pm
Thanks madjack!!
toypusher
Images: 324
Postby ralaco » Sun Aug 14, 2005 5:09 pm
You can try:
emachineshop
http://www.emachineshop.com/audio/flywheel.htm
It has an audio tutorial that let you draw parts step by step in 3D, in a flash and it’s free.
Raul
:twisted: :thumbsup:
ralaco
Images: 16
Postby mikeschn » Sun Aug 14, 2005 5:11 pm
Here's an easy one to play with, that has a little bit of horsepower. And it's only $28 if you want to register it...
I was able to make a drawing in just a few minutes...
Oh, btw, this runs on Windows, Macs and Linux...
:D
http://www.ribbonsoft.com/
Postby doug hodder » Sun Aug 14, 2005 5:16 pm
Congrats on your work so far MadJack...I've been wanting to learn that also, but don't seem to have the time...I'm a lot quicker with my old drafting board, T square, scale, compass and ellipse template....I'm impressed with your results for as long as you have been working with it...Someday.................doug :thumbsup:
Return to CAD secrets
