8 inch v. 12 inch
8 inch v. 12 inch
Postby EdwardJKopper » Sun Feb 22, 2009 12:35 pm
Hi, I'm new to this site and I recently purchased a 4 x 8 Benroy which the man nearly completed. The wheels are the 8 incher 4-bolts and the trailer is from HF. I see where I can replace these with the 4-bolt 12 inch wheels / tires.
Is this recommended to do? My buddy at work is saying to get rid of the 8 inchers.
Thank you for any insights.
-ed
EdwardJKopper
Postby satch » Sun Feb 22, 2009 1:04 pm
If the traier wieght doesn't go over the tire specs, I would say it's fine. Most use bigger tires because the look better.
If it itches. scratch it
Rick
satch
Images: 63
Postby mikeschn » Sun Feb 22, 2009 1:09 pm
Yep, it's mostly about looks...
got a picture of that?
Thanks guys
Postby EdwardJKopper » Sun Feb 22, 2009 1:12 pm
I am going to go take pics of it today and I'll post on here.. Thanks for the quick replies as well :thumbsup:
-ed
EdwardJKopper
Postby satch » Sun Feb 22, 2009 1:22 pm
Keep in mind, if you do try a change, HF axles are metric, I'm not sure you be able to find replacement hubs for it, plus on most, the hub face is very close to the frame, so you may not find another tire to fit without rubbing on the frame. Take measurements of everything before you buy anything. The only possible solution would be is to buy HF hubs and 12" tires (they don't have any bigger), or replace the whole axle. Keep us updated. :thumbsup:
Rick
satch
Images: 63
Thanks again
Postby EdwardJKopper » Sun Feb 22, 2009 5:07 pm
Thanks Rick ,, good info.. I'll keep you posted and i'll get some pictures on here as well..
ed
EdwardJKopper
