Which of these profiles do like best for a standie?
Postby martydukes » Mon Feb 23, 2009 10:04 pm
I've recently acquired a trailer and am going to build a light standie similar to the original puffin.
I have been thinking about 2 different designs and would like some input.
which of the following do you like the best? I'm thinking that the squared off one would be easier to build but I'm not sure.
Also, do you think that a rounded trailer would be more structurally sound?
or
martydukes
Postby Miriam C. » Mon Feb 23, 2009 10:15 pm
Well Marty, either will be as strong as your joints, glue and screws. My only issue with the square builds are getting those angled edges together in a way that will not leak some day soon.
Postby tinksdad » Mon Feb 23, 2009 10:21 pm
It's just my two cents worth; but I'm partial to curves. 8)
tinksdad
Images: 155
Postby martydukes » Mon Feb 23, 2009 10:23 pm
I'm leaning toward the curved one myself after looking at them for a while..
do you think it is possible to bend ply around corners like this?
martydukes
Postby Senior Ninja » Mon Feb 23, 2009 10:38 pm
Hi Marty,
Not only is it possible to bend plywood, I've actuall done it. To bend the front, I used a single four by eight piece of quarter inch plywood. I fastened the top at exactly the place where I intended to hinge the hatch which was exactly eight feet from the crosspiece ia the front bottom. Gosh that sounds complicated, but I can tell you it was easy. I then placed a big thick towel where the bend was going to be and poured a entire kettle of boiling water slowly over it. An hour later it was close enough to allow me to fasten it to to the sides and front bottom piece. A similar process bent the hatch.
Good luck.
Building the TD was the best thing I ever made.
Senior Ninja
Postby Wimperdink » Tue Feb 24, 2009 12:08 am
likes and dislikes aside, I would suspect the rounded profile would be less apt to experience roof sagging later on.
Wimperdink
Images: 33
Postby martydukes » Tue Feb 24, 2009 11:05 am
How about this one?
martydukes
Postby Miriam C. » Tue Feb 24, 2009 11:44 am
martydukes wrote:How about this one?
Looks good! Now just put the door away from the front so you can drop the floor to gain standing height without the TT being too tall. Besides you will need that corner. Why waste a perfectly good corner. 8)
Postby Michele » Tue Feb 24, 2009 12:19 pm
I prefer the rounded one.
Michele
Images: 120
Postby Senior Ninja » Tue Feb 24, 2009 12:41 pm
In the FOR-WHAT-IT'S-WORTH-DEPARTMENT Maybe FWIWD Marty,
I like the rounded shape both because it looks "retro" and I think it makes for a stronger panel. Anyway FWIWD and you paid exactly nothing for it.lol
Senior Ninja
Postby Wimperdink » Tue Feb 24, 2009 1:28 pm
Much better... I would still try to go with a slight slope where you have the flat area on top. There again no sag. Thats a more appealing design than the others imho.
Wimperdink
Images: 33
Postby Mini Renegade » Tue Feb 24, 2009 4:03 pm
Well if I can put my 2 pence in I prefer the rounder of the 2 first ones
If evvr tha dus owt fr nowt, allus do it fr thissen
Mini Renegade
Postby S. Heisley » Tue Feb 24, 2009 9:15 pm
...Me too. :)
Postby DougH » Wed Feb 25, 2009 12:34 am
I like them both but think I prefer the 2nd one. But then I might be biased.
Not quite a standie, I've got about 4' 8" inside. Just enough headroom to sit on the couch and have a couple inches of headroom (and also fit in the garage!)
DougH
Images: 86
Postby HubCapKevin » Thu Feb 26, 2009 2:51 pm
this is what i did .. Image
HubCapKevin
Images: 15
