I'm installing one on my motorcycle.
It has yellow constant and Red switched power wires.
Using a battery/power source on the bench, the only way the radio will turn on/operate is by tying the red and yellow together and connecting to the power source.
Ground is of course connected.
The radio has a clock and who knows what else running all the time.
As a test, I left the radio connected to the battery (small 10 Amp hr 12 volt) for two days, this morning, it is dead.
The radio was turned off, but the clock, etc, was still drawing power.
My meter showed a constant draw of .06 Amps.
My question is, can I simply connect the yellow and red power wires together, and then connect to the ignition switch controlled power source?
I realize the clock, etc. won't operate.
Is there any long term harm to the radio by wiring it this way?
Thanks!
Rob
