It is almost done except for the outer skin (may use paint or maybe FRP)..anyone used that before ?...I think I may move the axle back ...the tongue is very light...and yes the HF springs are very stiff.....has anyone tried removing one of the leaf's ??....and will probably get some kinda tire that is more like an ATV tire with less air pressure needed. The floor is 3/4 Plywood , the walls are sandwich construction with 3/8" outside and 1/8" inside with 3/4" insulation .
Thanks,
Scott
