norm perkiss wrote:I will build the next Tear the same way.
Norm
toypusher wrote:I built a Cubby just like the plans with the roof - NO substrate and there are lots of other ones out ther the same way. No problems that I have heard of. The best part about the Kuffel Creek plans is that they give you the small details on how to do most of the things. Anyway, my exterior skin which is .040 aluminum for the roof is directly on the spars and insulation, just polyuretheneed to the spars. The edge molding holds it in place after all. No need for anything else under it and I personally DO NOT plan on standing on my roof for anything (I have ladders for that)![]()
Kerry
IraRat wrote:Well, Kerry--don't the Kuffel plans tell you to use .030 aluminum?
YOU CHEATED!
KZ76017 wrote:I put the spars in, then covered them with the luan, glued them together with Power Grab and then floated the aluminum on top and secured it with molding on the sides.
Check it out here: http://www.flickr.com/photos/twisted76017/34715631/in/set-138594/
