This can't be good....
Postby Micro469 » Sat Mar 07, 2009 10:35 am
Mark72 wrote:Are you sure you didn't end up with a kerosene generator? That might explain why you are getting so much fuel. My AGM kerosene lantern will run on white gas if you preheat the generator first. If not you get too much raw fuel resulting in amazingly similar results.
Mark
Part#200A5891
Doesn't say for what gas.....Looks the sam3e as the old one......
John
Micro469
Images: 382
Postby rainjer » Sat Mar 07, 2009 11:09 am
Try putting the tip form the old generator on the new one.
Jeremy
rainjer
King Koleman
Images: 11
Fuel
Postby HossHoffer » Sat Mar 07, 2009 8:22 pm
You describe exactly how my older lanterns act when I get too much fuel in them. It's just a thought but take out some of the fuel and fire it up again.
HossHoffer
Images: 7
Postby PresTx82 » Sat Mar 07, 2009 9:47 pm
Several of you made mention of the "Coleman Forum". What is the website?
Mark
El Paso, Texas
PresTx82
Postby Micro469 » Sat Mar 07, 2009 10:41 pm
rainjer wrote:Try putting the tip form the old generator on the new one.
Jeremy
Tried that...no change.
John
Micro469
Images: 382
Re: Fuel
Postby Micro469 » Sat Mar 07, 2009 10:42 pm
HossHoffer wrote:You describe exactly how my older lanterns act when I get too much fuel in them. It's just a thought but take out some of the fuel and fire it up again.
It's got less than 1/2 tank fuel in it.Still no difference.
John
Micro469
Images: 382
Re: Fuel
Postby starleen2 » Sat Mar 07, 2009 10:46 pm
OK - so now you have a torch! :D - Just another way of looking at the whole situation :thinking:
starleen2
5th Teardrop Club
Postby Micro469 » Sat Mar 07, 2009 10:46 pm
I want to thank all of you for trying to help me with my problem, but I think this one is going to be for display only. I'm not going to spend more money on it for now, maybe later if I find a used beatup 200 that runs fine I may work on it again. I have a gut feeling that the entire valve assembly is just wore out and needs to be replaced.
:oops:
John
Micro469
Images: 382
Re: Fuel
Postby Micro469 » Sat Mar 07, 2009 10:47 pm
John
Micro469
Images: 382
Postby doug hodder » Sat Mar 07, 2009 11:23 pm
PresTx82 wrote:Several of you made mention of the "Coleman Forum". What is the website?
Here ya go Mark....they are doing some maintenance on it tonight and you probably can't get on. Go down to bulletin board service and get registered. There is tons of info for restoration and manuals, parts, knowledge. http://www.oldtownyucca.com/coleman/
Doug
Postby PresTx82 » Sun Mar 08, 2009 12:03 am
Thanks Doug. I've been there, but never saw the forum area.
Mark
El Paso, Texas
PresTx82
Postby rainjer » Sun Mar 08, 2009 12:09 am
Micro469 wrote:I want to thank all of you for trying to help me with my problem, but I think this one is going to be for display only. I'm not going to spend more money on it for now, maybe later if I find a used beatup 200 that runs fine I may work on it again. I have a gut feeling that the entire valve assembly is just wore out and needs to be replaced.
:oops:
John, I can tell you for sure that you do not need a new valve. If you are getting fuel & you can turn it off, it is fine. I think it is the generator. I would put a different one on even thou that is a new one. You may have just got a bad one.
One question, in you album you have a picture of it running, what did you do different since that picture?
Jeremy
rainjer
King Koleman
Images: 11
Postby Micro469 » Sun Mar 08, 2009 7:04 am
:oops:
Jeremy
Nothing.....That's the way she runs after she settles down, it just takes about 3 or 4 minutes.
John
Micro469
Images: 382
Postby satch » Sun Mar 08, 2009 8:30 am
Micro469 wrote:
:oops:
Jeremy
Plenty of time to roast some marshmellows :thumbsup:
If it itches. scratch it
Rick
satch
Images: 63
Postby doug hodder » Sun Mar 08, 2009 10:45 am
MMMMMMM....nothing better than a fuel cooked marshmallow. Now with 25% more soot. Helps build strong bodies 12 ways! ;) Doug
