doug hodder wrote:Here it is all bead blasted and stripped. I ended up using stripper on some of the sheet metal on the oven. It is so thin and even at a low angle, the bead blaster would tend to want to warp the metal. It appears that the original color was black. Now I need to do some sanding and a little body work on it on the few dents that it has. I'll have to use a high build primer and several coats over the pitted areas to smooth them over. I also found some patent numbers on it. Might be fun to do a search on them and see what comes up. Doug
doug hodder wrote:Know what is a bear???? put an oven back together and some of the sheet metal pieces have to move like 270 degrees when folding and not get any scratches on the hinges....yeah...like that is going to happen! Kind of a drag.....Doug
