Does it look okay? Is there any glaringly obvious problems that I'm overlooking? Total newbie at all this.
Cheers, Dewi
Dewi wrote:I haven't got a trailer yet for this, but this is the design I would like to build to...
Cheers, Dewi
Dewi wrote:How about this?
The red dots are hinge points, the rear of the TD drops down to form a step and there is a hinged wall that pops up with a barn door arrangement. Increases head height to a point, gives a bit more room inside the cabin area and eliminates alot of the leaking problems because the top 'hood' overlaps the outside of the TD. I should be able to install a fairly simple gutter beneath the 'hood' hinge, removing all the leaking problems in one swop.
The step on the base of the TD would fold into the bottom barn door of the folding wall... the top part of the wall would rest on the open barn door, securing whilst in transit.
If its a daft idea, please could someone tell me before I start getting all giddy... I really like this idea... but if its not doable, I think a standard Jim Dandy will be in order.
Cheers, Dewi
