What about a "clam shell" style pantry hatch
Postby Von Pook » Sun Mar 15, 2009 9:40 pm
What if, for the pantry opening, a "clam shell" style hatch set up? In other words, a lower hatch door, and an upper hatch door. The hatch doors would seperate about mid height of the trailer, allowing the lower to swing down, and the upper to travel up. It would require an extra latch system to hold the lower in place while in transit, but might allow for more use of pantry area. Thank you for your time
Eric, the camping sound guy
Von Pook
Images: 10
Postby Miriam C. » Sun Mar 15, 2009 10:17 pm
:thumbsup: :applause: It works! The one I remember best is Gern B's.
http://tnttt.com/album_ ... er_id=1437
If you look at the Galley Gallery you will see lots of ideas.
http://s134.photobucket.com/albums/q120 ... mview=grid
:thumbsup: Wish I had done mine that way.
Postby Boodro » Mon Mar 16, 2009 10:08 am
Checkout my album. I have what you describe. My hatch used to be full size , but I did a rebuild & found that this works very well. The bottom hatch has a strap on each side so it does not fall & hit my bumper. But like you said it does take 2 latch systems. I did them the same way . Good luck! :thumbsup: :thumbsup:
We are all travelers in this world , from the sweet grass to the packin house , birth till death , we travel between the eternities . ( Robert Duvall as Prentiss Ritter)
Boodro
Images: 101
Postby 48Rob » Mon Mar 16, 2009 11:36 am
48Rob
Postby Dewi » Mon Mar 16, 2009 12:06 pm
Rob, you have a beautifully done trailer :thumbsup:
Cheers, Dewi
Dewi
Postby 48Rob » Mon Mar 16, 2009 6:55 pm
Thanks Dewi!
Take your time, explore as many options as you can, and make your best choice.
No matter what you choose, as soon as you're finished, something different, better, more exciting, etc, will come along and make you wonder if you made the right decision... but fear not!
You made your choice based on what worked the best for you at the time.
All the other cool ideas you didn't have room for, can be used on your next trailer... ;)
Rob
48Rob
Postby Von Pook » Mon Oct 12, 2009 1:44 pm
The "clam shell" pantry hatch system, works like a charm. Thank you for your help in thinking this through, Eric Image The lower hatch works well as a mini bar when in the closed position also :beer:
Von Pook
Images: 10
