What kind of door hinge did you use?
Aluminum Piano Hinge
6
17%
Stainless Steel piano hinge
20
57%
Custom piano hinge from Grant
2
6%
Regular door hinges
5
14%
Other type (please explain)
2
6%
Total votes : 35
Postby JunkMan » Tue Aug 23, 2005 8:23 pm
I am getting ready to order door hinges, and think I want to use stainless steel, but aluminum is much cheaper. What did you use, and are you happy with it?
Jeff & Odie
Black Hills of South Dakota
JunkMan
Images: 50
Postby Chris C » Tue Aug 23, 2005 9:02 pm
Just a personal opinion. I think you'd be happier with the stainless steel over the long haul. Save a buck or two on your interior lighting and spend it on hinges if you have to.
Chris :D
Chris C
Postby Woody » Tue Aug 23, 2005 9:10 pm
I used stainless piano hinge also. Have not one complaint about it
Woody
E-mail: [email protected]
Woody
Images: 26
Postby len19070 » Mon Sep 05, 2005 9:37 pm
I used a standard Brass 4" butt hinge. I thought that it would look a little more "late 40's". I had seen these used on an origional "Cabin Car" and the trailer I was building was very similar (only smaller).
http://www.nicksteardrop.com/cabincar.htm
http://pg.photos.yahoo.com/ph/len19070/ ... /my_photos
Happy Trails
Len
len19070
Images: 24
Postby asianflava » Tue Sep 06, 2005 12:44 am
I've had my hinges from Grant laying around for a long time. I finally mounted my doors recently. Thanks to those offset hinges, installing the doors was a snap. The only alignment I had to worry about was vertical. After they were installed, I was able to see how much to trim the latch side.
asianflava
Return to User Polls
