Ventline fan???
Ventline fan???
Postby bbarry » Tue Mar 24, 2009 8:08 am
Anybody using the cheap Ventline fans sold on eBay?
It does't look as if it moves a lot of air, but considering the size of our trailers, perhaps may be appropriate. Anyone have experience with these? At $40-45 shipped, it sure is attractive compared to $100+ for other fans.
Brad
Brad
Jack of all trades, master of none.
Kampster build thread
bbarry
Images: 159
Postby Classic Finn » Tue Mar 24, 2009 10:15 am
Hi Brad
I havent read any folks having that fan however the Fan tastic fan has real good feedback. And real good service as well.
Here,s the link. http://www.rvvent.com/index2.htm
Scott is the name of the gentleman there that many have purchased from.
Including myself even though I live in Scandinavia. ;)
Classic Finn :thumbsup:
Classic Finn
Midnight Sun Voyager
Images: 146
Postby madjack » Tue Mar 24, 2009 10:38 am
Brad, we had one in an old class "C" motorhome...it was extremely noisy...I have read of a few who tried them and were disapointed...if you want less expensive than a Fantastic Fan, try the O2Cool units from WalMart...you will havvta play around with them a bit to use as an exhaust fan but at less than 20USD they work well...............
madjack 8)
Postby b.bodemer » Tue Mar 24, 2009 10:47 am
I use that vent..........but with the excellent air circulation I get from the door windows and front windows I never even hooked the vent up for power. :lol: :lol:
Barb
b.bodemer
Images: 328
Postby Arne » Tue Mar 24, 2009 9:33 pm
I had one.. same problem... noise.. and only one speed.. high.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby bbarry » Wed Mar 25, 2009 8:25 am
Thanks for the thoughts. I just can't see spending 12-20% of my total build cost on a vent! I'm contemplating using the non-powered version and mounting a computer fan in it.
Brad
bbarry
Images: 159
Postby bbarry » Wed Mar 25, 2009 8:41 am
madjack wrote:Brad, we had one in an old class "C" motorhome...it was extremely noisy...I have read of a few who tried them and were disapointed...if you want less expensive than a Fantastic Fan, try the O2Cool units from WalMart...you will havvta play around with them a bit to use as an exhaust fan but at less than 20USD they work well...............
madjack 8)
I've searched and found this setup:
but I think I'm looking for something a little more permanent.
Brad
Brad
bbarry
Images: 159
Postby Kens » Wed Mar 25, 2009 9:22 am
I used the ventline brand. Loud is all I can say. Replaced the fan with a computer fan for less than 20bucks. Works fine but rarely use it. Bought same vent with no fan for second tear. Ken
Good day every day!
Kens
Images: 26
Postby mechmagcn » Thu Mar 26, 2009 6:53 am
On my TD I used the Comfort Air from Surflo. It is as promised and is actually whisper quiet. The fan control is a rheostat, so infinite speeds are achievable. Here's a link http://www.shurflo.com/pages/RV/rv_cate ... eries.html
Jeff & Micki
53 F100
Mercedes turbo diesel
Teardrop "finished" as if they ever are
You can never be lost if you don't care where you are going!
mechmagcn
Images: 56
Postby Wimperdink » Thu Mar 26, 2009 11:33 pm
yep mine was built with one of those.... Same opinion here.... its loud and only one speed... High. I've been considering installing a reostat on mine to slow it down a bit but not sure its worth the trouble. It pushes a lot of air and I get used to it after about 5 or 10 minutes of it being on.
bbarry wrote:Thanks for the thoughts. I just can't see spending 12-20% of my total build cost on a vent! I'm contemplating using the non-powered version and mounting a computer fan in it.
I don't think 1 computer fan is going to give you the results you are looking for.
Wimperdink
Images: 33
Case Fan
Postby Shadow Catcher » Tue Apr 14, 2009 8:55 pm
A computer 120mm case fan will put out 35 to 100CFM depending on speed and Db. I plan on using a couple of them with speed controller. I saw one 25mm case fan advertised,low rpm high CFM. Curved blade design has a contribution to lower amount of sound.
Postby bbarry » Tue Apr 14, 2009 9:34 pm
Kens wrote:I used the ventline brand. Loud is all I can say. Replaced the fan with a computer fan for less than 20bucks. Works fine but rarely use it. Bought same vent with no fan for second tear. Ken
I couldn't justify spending the bucks for a "real" vent fan. So, I'm going Ken's route. I have the regular powered Ventline fan now and if I get tired of the noise (actually, now that I have it and tried it out, it doesn't seem that noisy) I may replace the fan with a computer fan.
Brad
Brad
bbarry
Images: 159
