Trailer Repair (updated - done)
Postby doug hodder » Sat Apr 04, 2009 7:19 pm
Jeremy...that really looks good outfitted with all that blue gas stuff! Doug
Postby rainjer » Sun Apr 05, 2009 11:02 pm
Construction is done except for a couple doors!!!!
Here is the large utensil drawer. I need to edge band it, sand it & seal it & it will be done.
Here is the slide out shelf. It will hold my cutting mats & dish drainer while traveling. I just need to sand & seal it & it will be done. I also need to put 2 dividers in the cooler tray slide out then sand & seal.
My new hatch support. There will be one on each side. I had some wet paint on the left side so I will attach it tomorrow.
Jeremy
rainjer
King Koleman
Images: 11
Postby Mauleskinner » Sun Apr 05, 2009 11:09 pm
Looking great!
I like the hatch support...good idea. I'll have to file that away for when the time comes.
David
Mauleskinner
Postby rainjer » Mon Apr 13, 2009 8:58 pm
I figured it was time for another update.
I got the galley done (for now) tonight. I am not happy with my cooler tray so I am not going to worry about finishing it for now. I will rebuild it at a later date.
I have a small amount of touch-up to do on the paint, put a coat of polyurethane on the hatch skin, re-install the lights & the galley area will be done. The other tasks to complete are cutting the hole in the aluminum for the roof vent & installing it and putting my edge molding on with sealant. I also need to re-bolt my tongue box back on. I have 2 more weeks to finish before I head for the Dam Gathering.
Jeremy
rainjer
King Koleman
Images: 11
Postby rainjer » Wed Apr 15, 2009 10:25 pm
The galley hatch is done!!! I just need to put 3 more pieces of molding on with sealant and do some caulking & it will be water tight. I should be able to give it a bath next weekend before I head south.
Jeremy
rainjer
King Koleman
Images: 11
Postby Micro469 » Wed Apr 15, 2009 10:35 pm
How did you refinish the edge between the roof and the wall? Can't tell if you replaced the moulding......
John
Micro469
Images: 382
Postby rainjer » Wed Apr 15, 2009 10:40 pm
That is the molding I still need to to put on. I need 2 people & my wife was busy tonight. It is cut & drilled, I just need a set of hand to prevent getting caulk everywhere.
Jeremy
rainjer
King Koleman
Images: 11
Postby Micro469 » Wed Apr 15, 2009 11:02 pm
Looks Good!!!!
John
Micro469
Images: 382
Postby aggie79 » Thu Apr 16, 2009 8:21 am
:applause: Wonderful job and a very nice looking teardrop! :thumbsup:
Thanks for documenting your work.
Postby kennyrayandersen » Thu Apr 16, 2009 9:54 am
nice paint -- especially on the hatch -- makes it look fast!
Are those 12 or 13 inch tires?
I like your latch supports too -- nice and simple, but still look good a sturdy.
Looks better than down town!
kennyrayandersen
Images: 38
Postby doug hodder » Thu Apr 16, 2009 9:15 pm
The redo looks great Jeremy! See you at the dam for a closer inspection. I'll be bringing a couple of old stoves. Doug
Postby dreadcptflint » Thu Apr 16, 2009 11:24 pm
Nice redo. What material did you use for the countertop? It is very retro. :thumbsup:
dreadcptflint
Images: 19
Postby rainjer » Thu Apr 16, 2009 11:33 pm
kennyrayandersen wrote:nice paint -- especially on the hatch -- makes it look fast!
The are 12 X 4.8 tires. I have about 3000 mile on them so far. the seep to work ok. I would go with a bigger tire next time.
Jeremy
rainjer
King Koleman
Images: 11
dreadcptflint wrote:Nice redo. What material did you use for the countertop? It is very retro. :thumbsup:
It is Formica. There are 4 colors of the boomerang pattern.
Jeremy
rainjer
King Koleman
Images: 11
Postby rainjer » Thu Apr 16, 2009 11:38 pm
doug hodder wrote:The redo looks great Jeremy! See you at the dam for a closer inspection. I'll be bringing a couple of old stoves. Doug
Thanks Doug. I have had a good coach ;) I do have a 3 foot rule. I look forward to seeing the stoves in person.
I convince the wife last night that to let me build a carport on the side of the house. If I don't get it done this year, , it will go in the garage in the winter.
Jeremy
rainjer
King Koleman
Images: 11
