Lady Bug Winter Warrior - finally campable!
Postby Dewi » Wed Apr 08, 2009 6:53 am
Could I ask... coat with resin? What type of resin and why? (May sound like a dumb question... but I don't know the answer, so I thought I'd ask)
Liking the mockup very much!
Cheers, Dewi
Dewi
Postby Cliffmeister2000 » Wed Apr 08, 2009 7:10 am
Dewi wrote:Could I ask... coat with resin? What type of resin and why? (May sound like a dumb question... but I don't know the answer, so I thought I'd ask)
Cheers, Dewi
My recommendation:
http://www.rotdoctor.com/
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby Dewi » Wed Apr 08, 2009 7:12 am
Ahhh... seems obvious now you say... just confused me for a minute there (easily done) :oops:
Thank you Cliff!
Cheers, Dewi
Dewi
Postby starleen2 » Wed Apr 08, 2009 8:32 am
Cheers, Dewi
My recommendation:
Since the exterior walls are 5 mm ply- I need something to reduce the chances of delamination Plus add some strength
starleen2
5th Teardrop Club
Postby Cliffmeister2000 » Wed Apr 08, 2009 9:49 am
Cheers, Dewi
My recommendation:
I've never tried fibreglas, but many on here have. I'm guessing fibreglas will add strength. However, if you treat your trailer skin with 3 coats of CPES, make sure the ply is cut to size first, unless you don't mind ruining a blade or two. That stuff replaces the water in the wood with thinned epoxy, and the ply becomes rock hard for saw blades. Still easy to drill, however.
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
Cliffmeister2000
Images: 157
Postby mikeschn » Wed Apr 08, 2009 3:53 pm
Looking good. What is your expected headroom without the dropped floor?
Postby starleen2 » Wed Apr 08, 2009 10:10 pm
mikeschn wrote:Looking good. What is your expected headroom without the dropped floor?
The expected headroom with hatch extended will be 74". Total height from the ground to the highest point on the hatch in the closed position is 76" so it fits in a garage
starleen2
5th Teardrop Club
Postby starleen2 » Wed Apr 08, 2009 10:14 pm
Here are some picts of the subframe - I painted it before installation on the trailer. This add additional support for the floor and trailer and providing attachment points for the flooring
152134
152135
starleen2
5th Teardrop Club
Postby starleen2 » Fri Apr 10, 2009 7:50 am
Floor: ¾ inch plywood – very sturdy and no need for framing beyond the actual trailer it self. I used a sub frame constructed out of 2×3 s to support the camper floor over the trailer The underside of the floor is painted to seal the plywood. I applied sheet Aluminum to the underside of the floor to protect it from road debris and water spray. Bolted the entire structure to the trailer.
Completed flooring
152136
152137
152138
starleen2
5th Teardrop Club
Postby starleen2 » Fri Apr 10, 2009 8:44 am
Got out the scales and decided to weigh what I have.
Left wheel=130 lbs
Right wheel=135 lbs
tongue= 58 lbs
total= 323 lbs
152136
starleen2
5th Teardrop Club
Postby toypusher » Fri Apr 10, 2009 8:51 am
Scott,
Aren't you going us any insulation in the floor?
toypusher
Images: 324
Postby starleen2 » Fri Apr 10, 2009 9:40 am
toypusher wrote:Scott,
No insulation on the floor - don't really need it here in Texas plus the bed will be elevated above the floor. We usually put down an area rug over the finished flooring anyway. However, the walls and ceilings and hatch will be insulated thoroughly - for the summer time heat (as mentioned before - this is Texas!~)
starleen2
5th Teardrop Club
Postby RAYVILLIAN » Fri Apr 10, 2009 4:08 pm
It's looking great man. Can't wait to see her done. It should go faster now at least mine did. Seems like it took for ever to build the walls than it went togeather pretty quick than it took along time to do the epoxy on the out side.
still enjoying my Steen's thanks again
Gary
111961Image
RAYVILLIAN
Images: 109
Postby mikeschn » Fri Apr 10, 2009 10:29 pm
That looks to be a bit wider than the Escape Hatch was... so what is it? About 72"?
Which way do you plan on sleeping in it? Crosswise or lengthwise?
Postby SmokeyBob » Sat Apr 11, 2009 9:54 am
Hi Scott
A question about your floor.
What keeps the part of your floor that extends out past the frame from sagging once you have the weight of the walls on it.
Looking forward to seeing your camper when it's finished.
Pics for Building the Alegria I
To view video click Here
Bob & Judith
SmokeyBob
Images: 161
