Hello,
I am really likeing the simple aproach of the weekender plans. Does anyone have more detailed plans? I understand how to build the exterior shell, but sam s little unclear how it all goes together.
Thanks
Tim
tstroud wrote:I was looking at some old posts. Did you ever play around with the idea of cooling this thing with the old camper fridge?
tstroud wrote:In that last set of pictures you added, is that 1/4 luan you lined the outside with?
tstroud wrote:Are you using 1x2's or 1x3's for sticks to frame it out. Ill bet the birch gives you a much smoother finish.
Thanks
Tim
tstroud wrote:I hope you dont mind me asking all these questions, and I appreciate your help. In your original plans where you used 1/2" plywood, you used a biscuit joiner the join the plywood peices for the sides which were longer than 8'. How did you do that using the 1/4 birch? Did you just make sure there was a board behind the seam to screw the plywood down at the seams? If so did you fill the seam with something similar to how you would with drywall? Was the seam noticable after paint? Do you have any pictures of your completed build after paint?
Thanks
Tim
