madjack wrote:Ed, I almost always encourage folks to "roll their own"...you get a custom frame designed specifically to your camper and the satisfaction to boot...although it has been a couple of years, my last frame, built with 1x2x3/16 channel and a 1500# Dexter torsion axle ran less than 500 bucks with tires/wheels/fenders included...I did have a 5' piece of 2x1/4 sq tube for the tongue on hand..........
Esteban wrote:I hired a local welding shop to make my 5'x10' frame. The outside of the frame was made from 2"x2"x1/8" tube. The A-frame tongue was made from 2"x3"x1/8" rectangular tube. The 4 cross supports were made from 2"x2"x1/8" "L" angle. The L cross supports are lighter than tubing and easy to drill holes through for bolting the floor to the frame.
On my "next" frame I'm considering making the outside of the frame from "C" channel to make it easier to attach the outside walls to it, which I prefer to cover the trailer frame. With "C" channel it'd be easy to bolt or screw the sides and floor to the frame. (I don't want to drill holes into tubing). I think it'd make wiring easier too because you can run the wire through the open "C" where it'd be supported. I might make it easier to wire to the side running lights too because it's be easy to drill through the side of the "C". It might help you to balance the trailer because you could drill into the "C" to attach the axle wherever it balances best.
I'd also be very tempted to attach one or two battery trays to the frame like halfdome Danny does.
kennyrayandersen wrote::shock:
Anyway, it will be REALLY robust with those gages.
BTW -- what is your projected weight, and what is the distance from the ball to where the teardrop vertical wall is? The design library has tables for determining what dimensions your tongue should be. Unless it going to be reall heavy and you tongue really long, you may not need so much -- if you need help interpreting the data, I'd be happy to look at the sizing according to the tables if you can provide some weights and dimensions.
kennyrayandersen wrote: Who knows what might happen and you'd only be able to build one. I say build the one you want. If you've been wood working for a long time then you won't have any trouble modifying the plans a little if you need to and so I don't think either of those will be beyond your capability.
madjack wrote:...let me interject 2cents wortha my thoughts on tongue construction..mind you, I am not a trained engineer but rather have many years of experience with many different types of trailers...a single tube tongue can work just fine BUT it is more prone to difficulties with both shimmy and eventual fatigue...at the very least, I prefer an "A" frame tongue or my actual preference, a "Y" frame...of course length of tongue has a lot to do with it and considerations for what you might wish to mount on the tongue...my present tear has a 5' long tongue, with a 1' deep front box(actually, integral to the cabin), a petcool and 20# propane tank mounted on it...a lotta stuff I know, so I built it out of a piece of 2X1/4" tube with 1X2X3/16 "C" channel side braces...works out very well for me.........
