When I turn the cars running lights on, the running light vehicle fuse blows. I've ground each light to the trailer frame. I tested each light before hooking it up and the light worked.
Hoping the wiring gurus have some sage advice. Do I have a bad ground or a short in the rear lights. Do I need to ground the trailer in a different way?
I've wired it for four flat.
The main ground is here on the frame.
The front running lights are spliced here to the brown wire on each side.
The front running lights are each ground to the frame.
The rear lights are here. Red is for running light and black for turn/brake.
Again, rear lights ground to the frame.
Any suggestions would be most appreciated.
