by Arne » Sat Apr 18, 2009 5:52 pm
The house paint collects dirt easily, going down the road it collects quite a bit over time...
The t/d was processed using a 'deglosser' I got from Lowes. Then I used an orbital sander with 60 grit on the whole t/d. It is now ready for paint.
The new paint is marine top deck paint and appears to be similar to interlux. It should leave a surface similar to fiberglas gel coat so it should stay cleaner, look better, and be easier to clean. They recommend not painting below 50 degrees... I'd like it about 70, so the paint will level better. Tomorrow, back to lowes for rollers, paint pans, etc. 2 coats of primer and two coats of paint... primer dried to touch in 4 hours, so will see how it goes if it needs sanding between coats. If so, will wait overnight.
