Del's canned ham build
Postby Elumia » Wed Oct 01, 2008 4:17 pm
exactly! Would they need to be epoxied? seems Titebond would be good enough for a wood to wood joint, and less expensive. Your temp block could be further from the glue joint too.
Elumia
Images: 15
Postby del » Wed Oct 01, 2008 5:45 pm
Now I understand the two piece, thanks Andrew and Mark. I was thinking about leaving those and skinning around them for the interior, then calling it a design feature.
del
del
5000 Club
5000 Club
Images: 410
Postby del » Sat Apr 11, 2009 12:59 am
Hi folks, time to start again on my little project. I now own a gray water tank, but it is 1 inch too thick to fit above the axle.
With only 3 1/2" of clearance, I am afraid it will come in contact with the axle. suggestions?
del
del
5000 Club
5000 Club
Images: 410
ham
Postby dandan » Sat Apr 11, 2009 2:56 am
Hi Del,
good to see you back on it ! :)
the 3.5" shown in the photo,
is that decreased when a load is placed on board ?
this may cause problems if anything is placed between the axle & floorpan. (if the tank can be reduced in size.) :thinking:
perhaps mount it to the rear of the axle so its protected by it &
place a stone gaurd beneath too ???
best rgds dan. :thumbsup:
Nostalgia's not what it used to be !!!
dandan
Roswell Club
Images: 214
Re: ham
Postby del » Sat Apr 11, 2009 11:11 am
dandan wrote:Hi Del,
is that decreased when a load is placed on board ? Yes, how far is the question?
this may cause problems if anything is placed between the axle & floorpan. (if the tank can be reduced in size.) :thinking: Plastic tank, pics later
place a stone gaurd beneath too ??? The black tank is already there.
del
del
5000 Club
5000 Club
Images: 410
Postby dandan » Sun Apr 12, 2009 3:57 am
good luck
dandan
Roswell Club
Images: 214
Postby del » Thu Apr 23, 2009 12:49 pm
I have many projects this spring so progress is slow, but I did buy a pair of stabilizer jacks from my Uncle. Took one appart and primed it.
del
PS my spell checker is not working today sorry.
del
5000 Club
5000 Club
Images: 410
Postby del » Sat May 09, 2009 7:44 pm
Dry rot ate my tyres. That was a good excuse to buy new ones right? New tyres are 225/75tr15 and being 10pr, they are rated at 2830 lbs each (could have bought 8pr for $0.20 less). Old ones were 235/75r15. Does anyone know what the lug bolts should be torqued at?
The two new ones with the better of the old ones.
del
del
5000 Club
5000 Club
Images: 410
Postby caseydog » Sat May 09, 2009 8:39 pm
del wrote:Does anyone know what the lug bolts should be torqued at?
del
Do you want that in SAE or metric?
CD
My build journal is HERE
caseydog
Images: 515
Postby del » Sat May 09, 2009 10:42 pm
del
CD
Do not care my torque wrench does both, just turn over.
del
del
5000 Club
5000 Club
Images: 410
Postby del » Wed May 13, 2009 11:12 pm
Here is my gray tank.
Still figuring out how to mount it. It holds about 30 gal? 30" x 54.5 x (5" near drain, 4" elsewhere). My thoughts are 2" x ? angle bolted on the ends.
del
del
5000 Club
5000 Club
Images: 410
Postby del » Thu May 28, 2009 12:32 am
My neighbor gave me an old tent trailer which I have been working on instead of my frame. In fact my other neighbor gave me a bunch of wood to build a car port, for over this build. :banana: :banana: For now the wood is on the frame. I did finish painting and even reassembled my stabilizer jack.
It escapes me why part is yellow. Now to do the same with the other side.
del
del
5000 Club
5000 Club
Images: 410
Postby starleen2 » Thu Dec 10, 2009 11:29 am
del wrote:It escapes me why part is yellow. Now to do the same with the other side.
del
So you can see it under a dimmly lit trailer -Imagine pulling in about twilight and looking under a trailer in which everything is Black - the yellow kinda sticks out and is easy to find :thumbsup:
starleen2
5th Teardrop Club
Postby del » Fri Dec 11, 2009 11:57 am
del
Hey I like that, now if I could only convince anybody that is why I did it? :thinking:
del
del
5000 Club
5000 Club
Images: 410
Postby del » Wed Dec 23, 2009 2:45 am
I have been working on two projects, my convertible dakota, and cleaning the garage. While cleaning the unpainted, and disassembled second jack was in the way. So I painted it, making matching jacks, cool huh?
del
del
5000 Club
5000 Club
Images: 410
