Southern Oregon Bob wrote:Snip.. I actually cut a pattern with my circular saw in 1/8", fined tuned it with a sander and then used that as a pattern and cut all of my peices with a router. Bob
Steve Frederick wrote:Southern Oregon Bob wrote:Snip.. I actually cut a pattern with my circular saw in 1/8", fined tuned it with a sander and then used that as a pattern and cut all of my peices with a router. Bob
This is the way I like to do it. Luan for a pattern is cheap, the experience/practice is good for you, and you can fine tune the shape before cutting the good stuff!
doug hodder wrote:Steve Frederick wrote:Southern Oregon Bob wrote:Snip.. I actually cut a pattern with my circular saw in 1/8", fined tuned it with a sander and then used that as a pattern and cut all of my peices with a router. Bob
The beauty of doing it that way is when the pattern is all said and done. you can just crank it out with a pattern bit on the router in the good stuff, and get a really clean 90 degree edge....it's helpful to save your templates however...I'm gonna do another and cut up the template for other uses....oh well... I guess I can just do a different profile...Doug
