This is my profile. The plywood needs to curve around the fron bend, which is an 18-inch radius curve.
The rear curve is a 36-inch wide by 24-inch tall ellipse. My hatch will start about 6-inches back from the beginning of the curve.
Any advice?
CD
doug hodder wrote:I used 1/8" Baltic birch, reason was, It was going to be painted and the Baltic takes on the epoxy much better than the typical ply. It gives a really nice uniform curve and finishes up nicely. It's dimensionally exact so that 2 layers will equal the 1/4" Baltic....not offbeat on the dimensions. If you are going to skin it in aluminum, you could probably get by with the Home Depot stuff...Doug
