I am really having a difficult time where to put the hookups for water and power. I really do not want to put any holes in the side of my project other than a door. To be honest I have not found any covers or such that do not look RV. I also would like the rear of the trailer to have as few things coming out of it as possible. (Less things to trip over)
For electrical do I do an male electrical outlet and hook it up with an extension cord.
Or do I attach an 50 foot cord that i pull out of the hole that I do not want to put in the side of my trailer.
Or maybe something in the tounge area and run wire down the chassis and connect to the galley area.
For the water. I am installing a ten (10) gallon tank with pump so I will need some port to fill it, also do I install a hose connection point so I can hook up to a faucet to save battery power not running the pump.
Ok thinking as I am writing this: I am building an A frame tounge. create a box in the tounge, its going to be made out of 2X3 steel. Run a 10 foot piece of extra 2X2 steel tubing (Ok i planned and bought to much 2x2) down the center from the box in the tounge to the back of the galley. Hard wire a 10 gauge 50 foot power cord through the galley down the 2x2 tubing and store in the box created in the tounge.
Do the same thing with the water connection. Run in the same 2x2 I know alot of you saying dont mix the water and electrical. but if the electrical terminates at a different point than the water does will it not be ok. I guess my trailer fire huh.
Than put the holes in the cover of the tounge box.
Advantages I believe more storage space in the tounge frees up space in the galley to store cords and hoses. I do not have the covers I am dreading.
I still believe I will have to have a cover in one side to have for a fill point for the (10) gallon water tank and can use the same style of fill cover I have for my Jeep gas tank to keep the same look.
