While down at the Dam gathering, I notice my tongue looked bent. I looked under the trailer but did not see anything wrong. I drove home 610 miles and it seemed ok. When I went to unhook the trailer from the Jeep, I leaned on the tongue box & the whole trailer went down. When I crawled under the trailer and looked, I found this crack at the rear if the tongue..
Here is what it looks like out of the trailer.
The only reason it did not break on all the way is because there was a 2 X 4 in side the cross member that supports my under floor storage.
Upon further review, the the piece is cracked around the hole on the other side of the tongue also. I will be replacing this piece and will be adding an addition cross member about 12" in front of this one.
Jeremy
