Fenders for partially recessed wheels?
Postby dmckruit » Thu Apr 30, 2009 9:52 am
Anybody know where I can find fenders that would work on a Grumman 2 type build? I would need fenders that are about half the width of regular fenders (about 4 to 5 inches), and work with 15" wheels.
I know I could probably get regular size and cut them in half, but with my luck that would probably turn out to be a disaster. (I don't need four 15" ashtrays. I don't even smoke? :D
Any suggestions would be appreciated.
dmckruit
Images: 212
Postby prohandyman » Thu Apr 30, 2009 10:16 am
Here is one idea. Kind of pricey. http://www.icontechltd.com/productcart/pc/Single-Axle-Fender-Skirts-c12.htm
I have the same dilemma. I am considering building some up out of foam insulation, with fiberglass coating, the painting. Steve Frederick has done this , with plywood backer for attaching.
Dan
prohandyman
Images: 785
Postby madjack » Thu Apr 30, 2009 12:29 pm
...whatever you use, it will probably require some fabrication on your part...one option to consider, is the fender flair/extensions used on Jeeps and other vehicles which run wider tires.......
madjack 8)
Postby Mini Renegade » Fri May 01, 2009 4:43 am
have you looked at Morris Minor Traveller rear wings? very much like the traditional teardrop shape but are narrower as the wheel sits 1/2 inboard.
I`m pretty sure you will be able to get some over there.
http://classiccarsales.ie/files/cars/im ... 0a4201.jpg
If evvr tha dus owt fr nowt, allus do it fr thissen
Mini Renegade
Postby Micro469 » Fri May 01, 2009 2:54 pm
Check out Steve Fredrick's build.....
http://www.campingclassics.com/lodge5.html
John
Micro469
Images: 382
Postby Rick Sheerin » Sat May 02, 2009 5:53 am
prohandyman wrote:Here is one idea. Kind of pricey. http://www.icontechltd.com/productcart/pc/Single-Axle-Fender-Skirts-c12.htm
Dan- you might want to check with Steve, I know he was having some trouble with the end product bubbling up underneath the paint. Don't know if he fixed the problem or not.
Rick S
1996 Casita Spirit Deluxe 17ft
Careful with that Axe, Eugene
Rick Sheerin
Images: 100
Postby prohandyman » Sun May 03, 2009 7:31 pm
Fender skirts ready for glass.
Dan
prohandyman
Images: 785
Postby dmckruit » Mon May 04, 2009 7:22 am
Wow! You knocked those out fast! I am still debating what I want to do for my build.
I was thinking about maybe buying a fender from tractor supply and having it cut in half.
dmckruit
Images: 212
Postby Nitetimes » Mon May 04, 2009 8:54 am
dmckruit wrote:Wow! You knocked those out fast! I am still debating what I want to do for my build.
The only problem with that is unless you get the right one the lip on the back side will be almost a 90 and the front side is radiused.
They do make some that are radiused front and back but you have to look for them. You might want to check with Viking on 68, Bill can get just about anything. If you explain what you are looking for he made be able to order you pre-made ones.
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby kennyrayandersen » Mon May 04, 2009 8:55 pm
the problem with buying them and modifying is that you have the cost of pre-made and nearly the work of scratch building them....hmmm
Pink foam and glass would probably not take any if much longer and you'd get the shape you wanted. You still have the labor, but should save on the cost.
kennyrayandersen
Images: 38
Postby dmckruit » Tue May 05, 2009 9:36 am
I was thinking of using these fenders from tractor supply. If I remember correctly both sides have radiused edges (although it is hard to tell from the photo). I was thinking of cutting them in half, installing mounting brackets on the cut edges and then I am "in like Flynn."
http://www.tractorsupply.com/webapp/wcs/stores/servlet/ProductDisplay_10551_10001_43295_-1______?rFlag=true&cFlag=1
dmckruit
Images: 212
Postby Nitetimes » Tue May 05, 2009 1:35 pm
dmckruit wrote:I was thinking of using these fenders from tractor supply. If I remember correctly both sides have radiused edges (although it is hard to tell from the photo). I was thinking of cutting them in half, installing mounting brackets on the cut edges and then I am "in like Flynn."
Those are the ones I was talking about. You'll have to actually see them to know. If I'd have seen this earlier I'd have stopped on my way by and checked. 8)
Rich
Nitetimes
7000 Club
7000 Club
Images: 194
Postby Nitetimes » Tue May 05, 2009 1:39 pm
How wide of fender do you actually need?? If I talk to Bill I'll see what he can get. He's picked up some new suppliers so ya never know.
BTW - I'm not trying to push Viking on anyone and I don't make any money by sending people there....I just know Bill can find just about anything for a trailer, and he's got lots of patience or at least more than me.... 8) :lol:
Rich
Nitetimes
7000 Club
7000 Club
Images: 194
Postby dmckruit » Wed May 06, 2009 7:17 am
I need about 4" wide. Wheels are 15".
dmckruit
Images: 212
Postby jdarkoregon » Thu May 07, 2009 1:08 am
prohandyman wrote:Fender skirts ready for glass.
Dan, could you share some glass info. Like how many layers will be required to hold up to being on the road, would that be the mold only or do you leave the pink in the fender when done?
I have been toying with the same idea for my new build
John
Innovation is essential
The world can be better
jdarkoregon
Images: 47
