That tear looks to have some nice features. Bone up on your 12V trailer basics, like knowing how to manage the deep cycle battery, here:
http://www.ccis.com/home/mnemeth/12volt/12volt.htm
Don't feel like you have to read ^ the entire thing, but do read the "Battery" and charging info.
Joan of Argghh!
Now what?
Now make sure your tow vehicle is up to snuff. Have all fluids replaced, ideally, but if not, then at least topped off. Engine oil, engine coolant, transmission fluid (perhaps add a trans cooler?), power steering fluid, and, most importantly, brake fluid. You really should have the brake fluid flushed and replaced with fresh brake fluid. If you've never towed before, you'll need your brakes at 100% of their capacity. This includes having fresh brake pads as well.
After your tow vehicle is put right for towing what looks to be at least 1200 lbs (check your tow vehicle's owner's manual for it's suggested maximum tow capacity), you'll need to concern yourself with the tow vehicle's hitch, the trailer's tongue weight, and the trailer's level ride attitude.
See:
http://tnttt.com/viewtopic.php?t=27404
Then, some tips for towing on the road!:
http://www.sherline.com/lmbook.htm
Don't ignore the VALUABLE advice in that last link! It could mean the difference between long days of sketchy handling and driving fatigue or a fun, trouble-free trip. You might be then compelled to modify your forum username. Hee!
Stay safe! Have fun! Do your research!
Above links were selected from Steve's alphabetized forum index:
http://tnttt.com/viewtopic.php?t=12276
Hope to see you camping sometime,
- Chris
