I am thinking of some type of gravity fed system to use for a sink and for drinking. Does anybody have any good pointers or ideas for such? I am thinking of at least 5 gallons.?
mikeschn wrote:There are many ways to do it...
Here's the way I did it in the Generic ET.
P.S. Here is the 5 gallon version...
Pick up bowl, fling water on ground.kennyrayandersen wrote:mikeschn wrote:There are many ways to do it...
How does it drain out of the bowl? Drill hole install regular stainless steel drain?
del wrote:Pick up bowl, fling water on ground.
del
mikeschn wrote:del wrote:Pick up bowl, fling water on ground.
del
Exactly!!!![]()
kennyrayandersen wrote:mikeschn wrote:del wrote:Pick up bowl, fling water on ground.
del
Exactly!!!![]()
I saw someone else had a similar setup, but had a bucket for the 'gray water'. I don't know what the rules are for what can be flung...
