Help, My trailer is sick
Postby pete.wilson » Sat May 16, 2009 8:26 pm
Hey
I like the methods mentioned already and being it's on the top surface, you might try using 5 or 20 min epoxy and thin it with alcohol and apply it into the hole, cover with good wax paper and then set some heavy flat object (Steal works good) on it until the epoxy hardens. Then sand the area and seal with your favorite product. Thinned epoxy will absorb into wood very well and is great for end grains. Old RC airplane stuff for fuel proofing engine bulkheads from the nitro used in glow fuel or gasoline/oil powered airplanes.
Pete Wilson
Why hasn't anyone found a dead bigfoot? When was the last time you found a dead deer, bear, coyote, fox, squirrel, etc. that died in the woods.........Hmmm.
pete.wilson
Postby H@nk » Sun May 17, 2009 2:56 pm
Steve_Cox wrote:
Walt M wrote:Sreve up here we call that a "dutchman" Walt
Yup, "dutchman" down here too
As a real Dutchman. you HAVE to explane your answer.
I hope its not the bad Dutchman?
Grtz Henk
Old bread isn't hard, no bread, that's hard.
H@nk
Images: 81
