sedanman67 wrote:I am going to be welding up my trailer in the next week or two and need advice on the length of the tongue. The trialer will be a 5' wide cub/modernistic with an a/c unit in the tongue box. Trialer steel is 2"x2" 1/8 square.
angib wrote:Hey, guys, it's a free world, so you can make the tongue as long as you like.
But:
- Check out just how short tongues are on most vintage teardrops. On the Mechanix Illustrated plans the tongue is 24" to the hitch center.
- The longer you make the tongue, the stronger it has to be made.
- A longer tongue makes a bigger storage problem, if you're tight on space.
Andrew
Mike (the smart-ass) wrote:Does that suggest a spreadsheet to you Andrew?
angib wrote:Mike (the smart-ass) wrote:Does that suggest a spreadsheet to you Andrew?
Neah..... I was thinking of a telepathic control virtual reality sorta thing - as you think of what you want, a model appears before you on your screen.
I've got just a couple of little bugs to fix - it should be up and running in 10 minutes.
Andrew
But:
Andrew
